Results 1 to 31 of 31
    Senior Member Three Rings wildtouch83's Avatar
    Mar 04 2013
    United States
    MMI hidden menu help
    So, hidden menu works. I've turned on front and rear footwell lighting. And I have followed the procedure (twice) for enabling the option to control them in the MMI. My option is still grey though. Any thoughts on what I missed?
    http://imgur.com/a/jzh9W
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    I don't have an answer but was trying to get into the green screen the other day and it wouldn't work. What button combination were you pressing?
    Mar 04 2013
    United States
    from the Car menu press Car + Menu and hold until the green menu begins to load.
    Dec 05 2010
    Sydney Australia
    Does this menu allow you to change the brightness of your LED DRLs? Is it safe to change things?
    Account Terminated Four Rings
    Sep 13 2014
    New York
    What do you do with this hidden menu?
    Mar 04 2013
    United States
    Quote Originally Posted by S4DownUnder View Post
    I was able to disable the wink of the LED DRLs but I don't recall seeing a brightness control with this app. You can safely bump up the brightness a little on them. Keep in mind not to go too bright as they could become too distracting to oncoming traffic.
    Mar 04 2013
    United States
    Quote Originally Posted by Jimmy ny View Post
    It allows you to unlock features of the MMI that have been hidden; such as the footwell lighting. Some features require changes to be made via VAGCOM first. In my case, I purchased a Carista OBD adapter and their app for my iPhone. It is not as complete as the software from Ross Tech but it's got what I wanted.
    Oct 27 2014
    Park City, UT
    Quote Originally Posted by wildtouch83 View Post
    Thanks, that's what I thought and had tried to do. Tried again today...while car running and just in accessory mode; did not work. What year is your car? Mine is 2015 MMI with Nav, B&O and whatever else comes with the technology package.
    Mar 04 2013
    United States
    Quote Originally Posted by d1amund View Post
    Mine is a 2013. If it's not letting you in the hidden menu then it's not enabled yet. And for that you need either the VAGCOM cable/software or this Carista app and OBD adapter that I'm using.
    I contacted the Carista developers and I got in on their beta version right now. It worked and allowed me to adjust my footwell lighting finally!! woo! It's really the little things that excite me these days.
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    In the hidden menu on a facelift you also need to set 'Interior light' on ‘CAN Komfort’ in 'car/carbusassigment'
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 21.9.0 (HEX-V2)
    Dec 05 2010
    Sydney Australia
    Hey wildtouch83, thanks for the info on Carista. Looks interesting as an option vs Ross-Tech, which is super expensive and looks too complicated for me. One question: Do you know whether you can adjust DRL brightness using Carista?
    Mar 04 2013
    United States
    I'll fire up the app today and look for the brightness control for you. Stay tuned.
    Mar 04 2013
    United States
    just got around to checking...no option yet for the brightness of LED DRL with Carista.
    I'm working on exporting all of my settings and then will post here so you can see what's available.
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    We had the same issue on my car this weekend when we were enabling the ambient lighting feature. My interior lighting option was greyed out, but the user from here helping me with it was able to figure out what step we had missed. Facelifted vehicles require an extra step that pre-facelift ones did not.
    I don't want to necessarily volunteer the guy that helped me do it, so I'll PM him and direct him to this thread to see if he can help you.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Mar 04 2013
    United States
    Quote Originally Posted by HazeMyth View Post
    appreciate the help. I was able to get mine cleared up!
    Jul 17 2015
    Colorado
    Glad t hear it.
    Are you running the stock lights for your footwells, by chance? I still have my stocks in, but I'm considering looking around for a red LED to match the rest of the interior night lighting. The white is honestly a little more distracting than I thought it would be.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Mar 20 2009
    Copenhagen, Denmark
    http://www.audizine.com/forum/showth...1#post10955618
    Rene Larsen
    Jul 17 2015
    Colorado
    ^ I knew I saw that thread on here somewhere before, but I was having a hard time finding it.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Mar 20 2009
    Copenhagen, Denmark
    Yeah, just 8 post up
    Rene Larsen
    Mar 04 2013
    United States
    Glad t hear it.
    I'm just using stock LEDs. I have tried just about every level of brightness and settled on just over half way for an acceptable level of light.
    Senior Member Two Rings mecham's Avatar
    Mar 02 2008
    Colorado
    this was skipped...
    Enable Ambiance Lighting.
    [09 – Cent. Elect.]
    [Coding - 07] -> Long Coding Helper -> Byte 16 Bit 6 - Set this bit manually to “1” - (1 = active)
    Jul 17 2015
    Colorado
    Quote Originally Posted by rlarsen View Post
    I must be totally blind today, because I don't see it. Then again, I'm having quite a stressing day at the office right now, so I'm admittedly a little more on the flustered side of things today. We all have those kinds of days I suppose.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    I have a 2014 and enabled this via Carista to get to unlock the MMI menu, and to also enable the ambient lighting both front/rear via Carista. My understanding is that you have to both enable it via VAGCOM or Carista, then you have the enable to screen option in the MMI. I went to the hidden MMI menu to activate the Interior Light (set it to both 1 and then 5 to see if it made a difference) under \main\car\devicelist, turned on CAN Komfort from 9/9 to 1/9 and also 5/9 under \main\car\carmenuoperatopm to see if it made a difference. All I end up with is a grayed out interior light screen option and the ambient lighting not working.
    Is there a specific step-by-step in order of activation that must be followed?
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by Loe View Post
    Did you enable what written in the posts below ??
    and
    http://www.audizine.com/forum/showth...1#post10966097
    Rene Larsen
    Mar 04 2013
    United States
    Were you able to get it working? If not, shoot me a PM
    Active Member Two Rings DCDJ's Avatar
    Jul 15 2014
    Audi RS5, Audi R8 V10+
    United Kingdom
    Same problem as Loe, couldn't get the "background lighting" working with Carista
    2014 Audi RS5: Capristo Exhaust • Satin Blue Wrap (Originally Suzuka Grey) • H&R Sport Springs • Reflective Blue Calipers • Dynamic Ride Control • Matte Black Alloys • 20% Tint All Round • Bucket Seats
    www.dcdj.co.uk
    Aug 09 2015
    Sarasota, FL
    Hey guys, I figured it out with the Carista App, you need to enroll to become a BETA tester if your on an Android platform on their website, or email them if your on iOS. Then after a couple hours, your app will send you a request for an update. You download the update and its the BETA version and then you can activate the ambient lighting via the App. Then you do the usual MMI hidden menu stuff.
    **Cliffnotes** The regular Carista App doesn't provide this function at this time as its in testing phase (at least for the B8.5). Contact them to become a BETA tester.
    Mar 21 2015
    There are a couple of threads going on now that you guys should look for. One in the A4 and one in the S4 section. Both are supported by Todor who works for Carista. All questions answered pretty much all of the time. You would have known about beta testing long ago.
    Jul 15 2014
    United Kingdom
    Good spot Loe, for anyone looking for BETA Info: http://www.caristaapp.com/beta/
    www.dcdj.co.uk
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    Off topic, no offense especially, but at least good for a bump - if my stressful days allowed me time to piss i'd be happy.
    Mar 21 2015
    Quote Originally Posted by DCDJ View Post
    You guys are light years behind over here. I would ask questions in the threads listed below, they get the most action.
    http://www.audizine.com/forum/showth...testing-wrench
    http://www.audizine.com/forum/showth...pp-for-our-car
