I know the stock intake does have other deficiencies but I was curious what a filter alone could do. I selected this particular aftermarket filter as it had an inverted cone top for additional surface area and was AFE's best flowing design (better than the Pro Dry, though the Pro Dry filters a little better). Installation was a perfect fit.
I logged 3 WOT runs immediately before and after (exact same ambient pressure and conditions). Bypass was 100% closed in all runs as per APR Stage 1 programming.
Boost pressure increased with the AFE filter roughly 15-35 hPA (highest in the upper RPMs) which equates to almost a 0.5 psi boost increase at its peak. This implies the filter was resulting in less negative pressure before the supercharger.
The PerfExpert app says I gained +8whp and +6 lb-ft torque. Not bad for a $70 filter and 20 minutes of time. I am going to assume the PerfExpert is being a little optimistic, but I've consistently dynoed 333-336whp on the stock filter even on different days (the app has SAE correction for local ambient conditions built in). And the boost increase would seem to roughly align. We'll see as I'll do some more runs this week.
Stock Filter
AFE filter
