Originally Posted by
034Motorsport
What code(s) are you getting? The spacer with Mini-Cat works much better than a simple spacer due to the built-in catalyst element, and we've had customers use it on B8 A4s with test pipes.
IIRC, usually the catalyst below efficiency code caused by removing the stock cat takes more than 15 minutes of driving to pop up.
Here's the codes from today.
OBD2 - confirmed
P013F 02 sensor delayed response - lean to rich bank 1 sensor 2
P013B 02 sensor slow response - lean to rich bank 1 sensor 2
OBD2 - pending
OBD2 - permanent
P0420 Catalyst system efficiency below threshold bank 1
Engine
P39C4
P39BE
And it was right around 15 minutes, but I wasn't timing it. Maybe it was 17 or 18? Point being it was fairly quick on my ride into work this morning.
The spacer was installed yesterday evening but I didn't drive the car afterwards. Just started it, let it run for 30 seconds and then turned it off.
