So my check engine light went on (2000 a4 2.8 quattro) and I took it to my mechanic to read the codes (below). I don't know much about the ECU but he thinks the ECU needs to be replaced. He tested the wiring harness and the MAF and both work fine. He wants $1900 to replace the ECU with a new one... That is a ton of money and I just need to know that is actually what's wrong and the only fix.
I bought the car at the start of the summer for cheap and it runs great minus this issue... Can you guys help?
16497 intake air temp sensor p0113
18011 internal control module p01603
16487 mass air flow sensor p0103
18010 power supply terminal p1602
17977 cruise control switch p1569
16825 EVAP emission control sys p0441
and a bunch of alarms
01367
01371
01372
01374
01370
01369
01368
01373
01366
