Originally Posted by
MosheAudi
Hi All,
I have Audi A4 B8 1.8 TFSI 2009 with GIAC STAGE1 and for quite some time as I drove the car,
overtime the gearbox started to jerk (Stutters) when changing gears especially when starting to drive (when the vehicle is still cold) and it feels that the car is lose a lot of power
and also i see that some time at the beginning of driving the car start in second gear instead of first gear.
I wanted to ask if my problem may be related to the gearbox oil? or is it a different problem?
Moshe.
Its time for dynamic oilchange, soft update and new adaption. Hopefully no real damage yet inside. As per reading, some specialists does not recommend add more torque for those gearbox then 65nm max, you probably got +100nm?, but all i was writing is cheaper then start repair gearbox. Check tech section there is thread not long time ago, you can make new adaption first and see what will be result. Just to test, especialy tuned multitronics keep loosing adaption with time. Latest soft for your car should be H12, you can check this with cable if you have, if you still have factory version it was faulty anyway.
