Results 1 to 21 of 21
    Jul 16 2015
    Scarborough, Me. NorthEast.
    What is a good weight for Tire/wheel?
    I have 20x10 Vossen wheels and 255/30/20's on my 12 S4 now.
    I ordered a new set of 19x9 Forgeline wheels with Michelin PSS in 255/35ZR19's
    I looked up on the UPS tracking info and they have them at 53 pounds per wheel and tire mounted.
    Is that fairly low weight?
    I bought these as my goal is to get my car in the 11's and it was suggested to me to lose the 20's and go down to some 19's.
    I haven't weighed my 20's yet but really hoping going to this wheel and tire package it will get me a tenth or two improvement in the 1/4 mile.
    Bill
    2012 S4 DSG, Phantom Black............................................. ...........................
    mods; StaSiS WC Sport Exhaust, gmg downpipes, StaSiS Challenge Suspension Kit, gmg WC Swaybar KIT front and rear, Adjustable front control arms, StaSiS 390-32mm mono6 BBK
    Revo Supercharger pulley, APR Coolant Performance System, Roc Euro intake, Revo Stage 1+, FORGELINE SC1 19x9 wrapped in Michelin PSS 255/35/19's
    1/[email protected]/[email protected]
    More to come, work in progress.
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by hdmlnium1 View Post
    Bill
    forgeline has some really nice looking wheels. which ones did you order? Most flow/rotary formed wheels in those dimensions are between 20-24 lbs i think. Fully forged wheels are probably in the same range and a little lower?
    you should post in the regional section next time you go to the track. i'd be willing to meet up
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Established Member Two Rings Sailingtime's Avatar
    Mar 18 2015
    2003 Vw Jetta GLI VR6 BDF Turbo
    NYC ��
    Sorry friend try again, 20" are heavy tire alone is,25lb. If you want less rotating mass go 19@17lb per wheel. It will cost you thou. 53lb is a lot of weight to move quickly. Also try staggering your fronts for less rolling resistance if you're all about your 1/4 mile runs.
    2015 6Spd Daytona, Tech, Sport Diff, Napa , B&O, Black Ops, Carbon Inlays.
    Jul 16 2015
    They are The SC1 19X9.0
    Im hoping to go this Friday if I dont have to work a night shift.
    Bill
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    Any cast wheel in 20x10 will be heavy, close to 28 or even 30 pounds. Unless your Vossens were flow formed, they should be around that weight.
    If low 1/4 mile times are your goal, it would be beneficial to keep the Vossens or Forgeline as your street wheel and pick up a super light weight wheel like 18" Enkei RPF1 for 1/4 mile. It's relatively cheap, strong and very light. Another thing, light weight rotors will give you better results than light weight wheels.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    18">19">20"
    The only thing you are gaining with a larger wheel is more room for a BBK.
    Jul 16 2015
    Quote Originally Posted by Sailingtime View Post
    Well it says 53lbs for each package, not really sure what they are package like, so I hope they work a lot better than my 20's
    Bill
    Aug 23 2011
    NH
    i think you guys need to reread his post
    he knows his vossens are heavy
    he ordered lightweight, forged wheels
    he probably knows they are going to be light, but was inquiring as to how light and what is ideal for improving 1/4 mi times
    right Bill?
    Mar 18 2015
    NYC ��
    Got it, sorry misread the post. 53lb per wheel is heavy especially on the 19" you should be somewhere around,40lb or less @19"
    Jul 16 2015
    Quote Originally Posted by KRp220 View Post
    right Bill?
    Yes that is correct. Lol
    Maybe what they were packaged in weights a few pounds. Lol
    I would have went with 18's but I do have a big brake kit in the front and don't plan on removing them so I had to go with 19's
    Bill
    Mar 18 2015
    NYC ��
    Interestingly enough, the weight of tires between 18"and19" is,about the same or within 1lb, so it's all wheel at 18" unless you go Hoosier if they make our sizes. So the margins are getting skinnier, between 18 and 19"
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Bill
    I'm going to say it's almost impossible to get a 19" set close to 40 lbs. Around 45 lbs. is great, 50 lbs. is good. The lightest 19" tire in our size range in 24 lbs. The lightest 19" wheels are going to be around 20 lbs. short of something very exotic. Anything you would save by going with a 18" wheel would be in mostly the wheel itself.
    If your shipping weight is 53 lbs., my guess is the tire and wheel package is around 50 lbs. That's still a pretty good weight savings over stock or your 20" wheels.
    If you are really serious about saving weight in terms of rotating mass, you need to consider light weight rotors. That will save a significant amount over stock.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Mar 18 2015
    NYC ��
    Quote Originally Posted by jran76 View Post
    Incorrect there is,a manufacturer and you have their tune, that has solid forged 19" @17lb I spoke with them at Waterfest wheels look nice as well little,raw on the finish thou.
    Jan 09 2008
    Winnipeg
    100% agree.
    I'm looking for new wheels and tires and want more grip than the PSS's provide and there are not many options, all of which are heavier than the PSS's (26-29lbs). And without spending a fortune on forged wheels most of the wheel and tire combos I come up with are 48-53 lbs. All of this is for 19".
    Mar 18 2015
    NYC ��
    Correct, however he didn't say cheapest, he asked if 53lb per wheel is "fairly light" for 19" the answer is No it's not light at 53lb for 19"
    So let's do kindergarten math shall we class following that the packaging weighs 3lb per wheel, we have 50lb per wheel - 24lb for tires that's. 26lb per wheel, that's one heavy wheel.
    Cheers
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    The ones you ordered look good but aren't the lightest.. If your plan was to keep the vossens and have a lightweight track setup, I'd opt for something else. Def go with the JHM rotors if you are serious about going fast
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    I'm well aware of just about every wheel option in existence.... The APR wheels aren't available.
    There are several options for 19's that weigh less than 20 lbs., but you're looking at something really expensive when you get into the 17-18 lb. range. The closest affordable wheel is going to be a flow-formed wheel or lower end forged wheel in the 20-21 lb. range. Those start out at a reasonable $1200-1500 for flow-formed (Renn, VMR, TSW) up to $4000 or so for a lower end forged wheel (BC, RSV, etc.).
    You mentioned a 40 lb. wheel setup and staggered tires- both of which are ridiculous options for different reasons. Please just stop....
    Senior Member Two Rings lexcruiser's Avatar
    Apr 01 2011
    In case it helps w/ the data you guys are putting up - I weighed my 19" Vorsteiner VFF 103s tonight wrapped in Conti DWS 06's. Weight of each wheel+tire came to ~51.8lbs.
    2015 Glacier White S4
    P+ / 6MT / Tech Pkg / Sport Diff / B&O / Alu-Optic / Magma Red
    XPel / 3M Crystalline 60% / APR Dual Pulley / Milltek Non-Res / VFF 103 Carbon Graphite 19x9.5 ET40 / H&R OE Sport / JHM Short Shift Kit & Solid Linkage / Recaro... Babyseat
    PAST:
    2011 Ibis White A5 - Stage 1
    2003 Brilliant Black A4 - Stage 1
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    seems to me like the op should have been more thorough or done more research prior to ordering new wheels, not the other way around.
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Jul 16 2015
    Ok wheels and tires came in today.
    here is the weight difference.
    20x10 Vossen C2's wrapped with Hankook V2's in 255/30/20's
    weight is 56 lbs even.
    19x9 Forgeline wheels wrapped in 255/35/19 Michelin PSS
    weight is 47.4 Lbs.
    Overall very happy with the weight savings.
    Bill
    Registered User Four Rings sonictuning's Avatar
    May 13 2010
    Gaithersburg Maryland
    We did a measurement here for our RS-51 wheels in the 19x8.5 with Michelin PSS tires and it came out 44 lbs. (unsprung weight). Hopefully this helps everyone looking for options!!
