Originally Posted by
AudiTurbo
The manual says when the rear defrost is on the heated mirror (regardless of the temp outside). I turn the car on, turned on the rear defrost and checked that was no power going to the wires for the heating of the drivers side. I didn't check the passenger side, but I guess it's probably the same.
That is why I want to check the fuse or relay, because the folding of the drivers side won't work either. Could it be the knob?
I did get 01734 - Potentiometer for Mirror Adj. Horizontal; Drivers Side and 01736 - Potentiometer for Mirror Adj. Vertical; Drivers Side
As far as I can recall, there is only one fuse for both mirrors. Not sure which one though. I am not home right now so I don't have access to diagrams.
When you say the power folding doesn't work, does it work on the passenger side mirror? Does the memory function work on passenger side mirror?
Also does the mirror control (up down side ways) work on the drive's side with the knob?
I think PO just installed normal base mirror assembly (no power folding, no auto dim mirror, no memory mirror) on the driver's side in your car. Probably someone clipped the mirror and he replaced it with cheapest option available.
And heat not working can be the case of broken wire inside the door panel or not connected at all.
Without removing the door card, you won't see if the connections are messed up. Also, the wiring at the door hinge is a weak link in Audi's. But I assume since the passenger side mirror is working from driver's side controls, the wiring at the hinge should be fine.
There is a slim chance but the mirror adjustment knob can be an issue as well. It may not be making proper contact when you put the knob in driver's side mirror position.
Too many variables.
I suggest, take out the driver's side door card and check for any loose/broken wires and compare the part numbers on mirrors, motors and door control module. Look up memory seats and power folding mirror retrofit. They have very good diagrams for you to reference.
I can take screenshots of wiring diagrams from ELSA WIN if you need.
I would suggest getting Axis's recommendation as well. We both have dug into these wires many times. He might have a different suggestion than I do.
Calling @Axis
