    May 02 2015
    United States
    Red face Be careful with your CV axles (tone ring, wheel sensor)
    So i did my front end with all new control arms TRE, etc...a month ago
    After which my abs light was on/off intermittently
    Some time passed, abs light ended up staying on.
    then
    I started getting a slight squeak. was definitely connected to braking as it would go away when i hit the brakes, but it was unusual.
    Ive had brake squeal before, but this was just different.
    I assumed i had 2 separate issues and proceeded to test the resistance on the sensor...zero reading....definitely needed to replace the wheel sensor.
    In the mean time i assumed it was my brakes squealing so i reconditioned them.
    slides, rotors, pads...brakes are perfect...
    squeak went away ish.....then came back..
    I started suspecting the sensor was somehow causing the squeak.
    I had attempted to remove the sensor when i was reconditioning the brakes but it was seized as seems to be very common.
    Finally had time today to pull the cv axle.
    Well..I had one only one issue.
    Sensor had got pushed into the tone ring.
    Looks like the tone ring ripped into the sensor until it made it to the copper wire
    then the tone ring disconnected from the cv and froze in the hub.
    So the intermittent abs light was while the tone ring was grinding away at the sensor
    then the solid abs light accompanied by the "brake" squeal was the tone ring seized in the hub and spinning on the outside of CV
    So i ended up getting a new CV axle just because the tone ring fell off. Sucks but i needed this done today and its just not worth trying to fit a new tone ring over a worn cv housing
    All back together, no abs light, no squeak or squeal.
    Careful with your CV axles when prying them out of the hub with minimal components removed
    May 02 2015
    United States
    BTW i got an $8 sensor from ebay. Actually bough a few just in case...I have no idea how these are sold so cheap?? Doesnt it cost anything to make and ship from china? Wow....
    Seems to work fine. We shall see....
    I mean even the autozone sensors are $85.
    http://www.ebay.com/itm/321401848172...%3AMEBIDX%3AIT
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Ebay ABS sensor are a great deal. Been using them for years. And I also keep a couple for spares.
    There are a lot of Ebay things I wont waste money on, but ABS sensors are very simple. Considering OE costs over $100, I felt it was worth the risk. And they work!
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Veteran Member Three Rings LA4's Avatar
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    I've also had great luck with the Ebay ABS sensors. I think I paid $11 for mine, and bought a couple. Even if hypothetically they were to go bad (not that I've had any issues) you'd have to go through a LOT of them before it becomes worth it to buy OEM.
    1998.5 A4 Quattro 1.8TQM AEB
    Stage 1 GIAC, 710N DV, ECS Snub Mount, ECS SS Brake Lines, A8 Rotors, Bilstein Sports/H&R Springs
    Oct 30 2009
    Miami, FL
    I've replaced basically all of mine with Chinese cheapies over the years, oldest being about 4 years ago. Never had a single issue.
    2018 S5 Coupe - stock for now
