Results 1 to 31 of 31
    Jul 11 2011
    SW USA
    cabin air filter brand preference
    I imagine cabin air filters (2012 S4) are like any other filters and there's a wide range of quality (there's sure a wide range of prices).
    Which brand do you prefer (especially for odor reduction)? Where do you buy them from?
    Apr 04 2012
    MSP
    Meh - if you can get something made in Germany go for it. otherwise they are all pretty good.
    I replace mine annually so doesn't have to last long...
    Jul 11 2011
    SW USA
    Do you have the secondary filter installed (the one accessible from under the hood on the passenger side)?
    Mar 21 2015
    ^ I had my cover off the other day and didnt see a filter on the passenger side. Which one are you speaking of?
    Jul 11 2011
    SW USA
    So you take the black plastic cowl shroud (or whatever it's called) off that goes the width of the car (you only need to loosen the one plastic screw near the hood hinge on the passenger side and you can flex the cover out of the way. There's a trapezoid shaped air intake grating underneath, and you can see the fan blades inside, but there's no filter in place. The grating just snaps in place so it's easy to remove, but there's a sensor attached to it (I assume this is the "air quality sniffer sensor."
    Apparently the factory stopped including the filter at this intake with the transition to the B8, but I guess you can special order the filter for it. I was just wondering how many people have done that.
    Mar 21 2015
    You got a part #? I know exactly what your talking about. Just ordered the inside filter.
    Jul 11 2011
    SW USA
    I'm not positive about this so please don't order until someone confirms it:
    http://www.ecstuning.com/Search/8KD819441/ES2564776/
    But jeez...$76, includes a new grill with built-in clips for the filter.
    I'm not sure how you get the sensor off the old grill (it's attached to it when you remove it). I tried to remove the connector and couldn't get it loose.
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    Quote Originally Posted by MA7 View Post
    Neither my B8 nor my B8.5 had those filters. Thought it was odd, but didn't question Audi's logic. Part # would be nice if you know it.
    Edit: Posted this a second late. Didn't see your last post^
    2015 Sepang Blue S5- APR Dual Pulley Ultracharged, APR TCU tune, CR-15, AG M580s, Girodisc F/R rotors, EBC Red Stuff pads, APR Open Box CF Intake, AWE Track Exhaust with AWE Resonated DPs, etc...
    2017 Mythos Black S6- Stock
    2020 Nardo Grey RS3- Stock
    Jul 11 2011
    SW USA
    When I took the cabin filter out of the interior there was some organic debris like tiny leaves that fell out when I removed it. I imagine those contribute to the smell or mold as they decay over time.
    So it does seem like it's worth putting some sort of filter over the engine bay grill.
    If nothing else, I think I might cut a piece of window screen to the shape of the current grill and take some carpet thread and a needle and wrap it around the frame of the grill to attach it. Or maybe buy a small furnace filter and cut the filter paper to size and stitch it onto the grill the same way.
    Trouble is, I can't detach the grill from the car because I can't get the sensor connector loose. It would be a whole lot easier to hook some sort of filter to the grill if I could remove the grill from the car and take it into the house to work on it.
    Jul 11 2011
    SW USA
    Here are some photos for those that don't know what we're talking about:
    It's underneath this shroud (note the flathead plastic screw in the foreground. Remove that.)
    after bending the shroud back you'll see this:
    and with the grill removed (but the sensor wires limit how much you can move it):
    edit: and here's a closeup of the sensor:
    May 26 2015
    Philadelphia
    i sprayed some lysol into the inlet when changing my filter and let the air run....helped alot.
    Jul 11 2011
    SW USA
    Quote Originally Posted by b8sfour View Post
    Thanks, I was going to ask that very question. Wasn't sure if the smell is entirely in the filter or on the walls of the ducts too.
    BTW, if anyone was wondering whether the people who say you can't clean these filters were wrong, they're not.
    I removed my filter, soaked it in a bucket of enzyme carpet cleaner, rinsed it thoroughly and soaked it again in plain water, then let it mostly dry and then used a vapor steam cleaner and thoroughly blasted all the pleats on both sides with steam, then dried the filter. I reinstalled it and it still smelled, and I'm not even sure that it reduced it any.
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    You can buy the 76 dollar filter that fits from ecs tuning but they don't sell replacement filters. kind of a scam if you ask me. I went back to the original that came with the car and wrapped the plastic grate with some old nylons. It won't trap fine particles but it keeps the leaves and other stuff out.
    Jun 29 2015
    Last pic above looks to me like you don't want to unplug the connector but twist the whole sensor so the pins line up and it comes of the cover.
    Looking a that view the little pin at say 7 o'clock needs to be free of hole then the whole sensor would rotate clock wise till tabs align
    Established Member Two Rings ctjibber's Avatar
    May 12 2011
    Connecticut
    Anyone know the link or part# to the "plastic screw in the foreground" in this pic:
    miltek nonres • strat intake • Adv1 5.0 titanium 19x10et39 • stasis v2 • alu kreuz • eurocode shifter • Jhm lw rear rotors • stoptech st60 355s • carbotech bobcat pads • 034 mounts • apikol differential mount • jhm knob • 034 trans mount spacer • eurocode sways+links • spc control arms • deval front+rear • ecodes • ecs street shield • pilot ss 255x35x19 • eurocode headers • JHM stage 3 clutch+lw flywheel
    Jan 28 2013
    It's a secondary air filter that seems to be an option for countries with polluted air (Mexico and China I think are two that have that option?). Here is a thread about it:
    http://www.audizine.com/forum/showthread.php/633911
    As for which cabin air filter, I don't know that it really matters. I've just been using a charcoal filter. Last time I got the Fram Fresh-breeze one and it seems to work just fine:
    http://www.amazon.com/CF11179-Fresh-.../dp/B00EAOIHPW
    Nov 23 2014
    North Carolina
    I went with MANN with charcoal. as far as the other one that we do not have, I found a thread about that and a guy retrofitted a Ford Taurus cabin filter for that location. I got the same one and will give it a go. need to get some lysol to spray through the system before I modify the filter to fit in ours.
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Jan 28 2013
    Quote Originally Posted by torinalth View Post
    Happen to have a link to that filter? I've modified a filter to go there, but if the Taurus one is a drop in, then that would be better.
    Jan 28 2013
    Quote Originally Posted by ctjibber View Post
    Didn't realize this was a thread resurrection.
    I've heard that called many things, expansion bolt, expansion clip, etc.. I think Audi is calling it a Shield Retainer:
    https://genuineaudiparts.com/parts/2...eld%20retainer
    Nov 23 2014
    North Carolina
    Quote Originally Posted by Lamprey View Post
    http://www.amazon.com/CF8109A-Fresh-...rch_detailpage
    it is NOT a drop in. but kinda close. I plan to do the modifications either today or over the weekend. and I'll post my results
    2019 X3 M40i - Sold
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    So are you guys basically adding an extra filter under the cowl, that is not normally there for North American models?
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Jan 28 2013
    LOL, that's the one I posted about in that other thread. I didn't realize it was a Taurus filter.
    Quote Originally Posted by sacandagaD View Post
    Correct.
    Jan 28 2013
    If you want a drop in you can find them on AliExpress. There are several to choose from, here is one:
    http://www.aliexpress.com/item/Well-...290177428.html
    Nov 23 2014
    North Carolina
    Interesting. I'd give that one a go. Just something I noticed, not sure if its because I have a B8.5 but the sensor location is on the far right side while the one in the picture is on the front. There was a fair amount of wire, so not sure if it would be a problem or not. Worst case I could clip the bracket off and use my new plastic welder to put it where it needs to be.
    I went ahead and modified the filter, and it works well enough the way I cut it. so, no need to change at this point, but it's an interesting option for a great price.
    2019 X3 M40i - Sold
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    thats for a pollution filter. only necessary to have if you live in china
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    May 12 2011
    Connecticut
    The ones on rear cowl/shroud/cover is just a flat head plastic screw though... Will the "shield retainer" work? I found the diagram but no screw listed: see below
    Mar 21 2015
    I would say this is the one
    https://www.ecstuning.com/Audi-B8_S4...3.0T/ES451343/
    Jan 28 2013
    I think 14S4GWM is correct. I was thinking about the "bolt" that holds the cover above the radiator, not the one you are talking about.
    May 12 2011
    Connecticut
    thanks guys
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    You guys could always try this one: https://www.europaparts.com/frecious...832e-407091117
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Established Member Two Rings djkyky's Avatar
    May 27 2015
    24 Audi Q3
    Estero FL
    I just throw in what I use for 2015 S4. Cabin filter is located inside the car under the glove box passenger side. I use the Wix 24227 carbon filter from Rock Auto. Fits without any mods.
