Results 1 to 40 of 48
    Jun 01 2015
    New york
    Options for new cv axle
    I've read around and it seems people have a hit or miss problem when purchasing the Feq or other axles. I need a new front driver cv axle as my current one is clicking. What's the best option for replacement?
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    Quote Originally Posted by Motomaniac22 View Post
    autozone reman(they recut the audi cores) or raxles for brand new. Autozone has lifetime warranty which is why i used them.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Jun 01 2015
    New york
    Quote Originally Posted by blitz2190 View Post
    So your saying get the duralast reman as apprised to the duralast gold?
    http://m.autozone.com/autozone-mobil...&showymme=true
    Jul 31 2014
    NH
    yeah, surprisingly the reman's seem to hold better and most figured it was because they use the oem audi core. I recommend keeping your core though and just paying the 120(I think that's what i paid after tax) That way you could always have yours rebuilt.
    Edit wow the b5 is even cheaper I paid 120 for the b6 3.0 axles.
    Jun 01 2015
    New york
    They are $60 for remans on the link I sent. Click on the link and look
    Jun 01 2015
    New york
    And core is $10.
    Jun 01 2015
    New york
    Anyone else have any input? I don't want it to fail anytime soon.
    Established Member Two Rings Michael_b5_s4's Avatar
    Jun 01 2014
    Tulsa, Ok
    I used O'reilly's Import Direct line... A little more expensive but no core. So I can rebuild my OE ones later.
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    I dont see any on autozone for reman driver side with manual trans.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Jun 01 2015
    New york
    Quote Originally Posted by Eurotuned_A4 View Post
    I didn't realize that. Good thing I have a tip car ;) lol
    Jun 01 2015
    New york
    Quote Originally Posted by Michael_b5_s4 View Post
    I don't have an o'rielly's near me :( I've never even seen one!
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Clicking while turning?
    Active Member One Ring Nerfmegently's Avatar
    Jun 22 2013
    Audi S4 B5 01.5 - Dodge Dakota 99 - Dodge Wayfarer Business Coupe 51
    Chicago/Illinois
    Hey I was wondering if you had any experience with Raxles and if so how much would they be and are they worth it over the autozone re-manufactured axles. I just found that my CV boots are torn on both driver and passenger side yesterday and could use some feedback before i jump on one or the other.
    Sep 25 2011
    Ohio
    +1 Autozone, about 15K on mine. They had the audi rings printed in them too so you know there legit.
    Jun 22 2013
    Chicago/Illinois
    Quote Originally Posted by cameratoaa View Post
    Thanks for the reply man! ill definitely look for the rings before i purchase them.
    Oct 05 2013
    Cabot, Arkansas
    One more for the AutoZone remans. Last weekend I changed out an axle on my sister's B6 A4 twice. The new FEQ had a bad inner CV joint right out of the box.
    Jun 01 2015
    New york
    Quote Originally Posted by Zba View Post
    Yes sir. It does it when it wants to do its not too bad yet. But the boot has been torn for a while and I didn't do anything about it.
    Sep 25 2011
    Ohio
    You sure its not the center diff fluid being low/old? that's what mine was, clicking almost grinding feeling/vibration when turning wheel full lock.
    Nov 05 2009
    Denver
    I ask because you would be surprised how resilient the joints are. Clean the old grease out of there and slap some OE boots with fresh grease and call it a day. The clicking is just because the joint is dry.
    Last I checked NAPA no longer had Audi joints.
    Jun 22 2013
    Chicago/Illinois
    It looks like the NAPA axles are actually cardone axles.
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Raxles. Expensive than autozone or China, but built to last.
    Jun 01 2015
    New york
    How do I check the diff fluid?
    Jun 01 2015
    New york
    Do you have to take the axle out to swap the boots? If so an extra $50 for an axle wouldn't really be bad
    Nov 05 2009
    Denver
    Not the outer boot. 50$ isn't bad for if it is an Audi axle. One thing to note though is that aftermarket boots suck. Something to consider
    Jun 01 2015
    New york
    How do I just change the outer boot? And where do I get a boot from
    Nov 05 2009
    Denver
    It's been a while since I did it but you loosen the nut before you jack the car up. Then steer full lock to the opposite side you are doing the boot on, remove the pinch bolt for the upper arms and remove the outer axle. This is the flat rate way, doing it in your driveway there is no reason to do it that way especially since it's a good idea to do the inner boot as well and get a fresh boot.
    Get Audi boots
    Jun 01 2015
    New york
    Get Audi boots
    Audi boots off ecs tuning are over $100
    Nov 05 2009
    Denver
    At least get the inner from audi. mind you, these are just suggestions. If you don't see the value just get a reman axle and be done with it.
    Jun 01 2015
    New york
    I just don't want to spend more money on pieces of an axle than a new axle itself.
    Nov 05 2009
    Denver
    All axles are not created equal. Find out if the NAPA axles are still Audi and go from there
    Jun 01 2015
    New york
    Will do. I'll go around to the 3 auto parts stores near me (autozone, car quest, and Napa) and see what the options are
    Jun 01 2015
    New york
    Does anyone have any experience with ecs's boot kit? Only $30. But I don't want the boot tearing anytime soon again. Also how do I know that getting a boot and more grease will stop the clicking? I don't want to order it then have it still click and end up having to replace the axle anyway
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    I called auto zone, pep boys, NAPA, o'riley's, car-done, and they all said they no longer carried the reman CV axles. This was last week. Only option would be Raxles or used.
    I've opted to rebuild my axle (inner boot is torn, so I'm just replacing and regreasing the inner/outer boot) since the boots are only $15 each lol. Buy the GKN ones, from what I know they're the same as oem. They come with new hardware too.
    My temporary fix was some spare CV grease, saran wrap, and duct tape over the tear. Let's see how long it lasts haha.
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Mar 01 2014
    Los Angeles, CA
    Buy the GKN boots. They're the same as oem. I used it the last time and it's holding up fine. Comes with a lot of grease and all new hardware. Buy it from Pelican Parts and you won't have to pay ECS's stupid shipping prices
    Justin
    #YEengineering
    Nov 05 2009
    Denver
    Because I was a professional Audi mechanic and have done this more times tan I can remember. I wouldn't want you to be mad at me right? lol
    Jun 01 2015
    New york
    Lol I just don't want to get new boots and have the same issue still. But I guess I will try new boots and grease and hope for the best
    Jun 01 2015
    New york
    I ordered the gkn outer boot kit. Was $15. Hopefully this fixes the clicking! Much better than paying for an axle.
    Jun 22 2013
    Chicago/Illinois
    Quote Originally Posted by Wagonholic View Post
    I just went to my local oreillys and autozone and while the oreillys did not carry any re-manufactured axles, the autozone did. I also confirmed that they were OEM axles since it had the Volkwagen and audi stamps on it.
    Jun 01 2015
    New york
    Quote Originally Posted by Nerfmegently View Post
    Awesome! I'll check in with that before my order ships.
    Jun 01 2015
    New york
    So I don't need to remove the bolts holding the axle to the transmission then? Just the axle nut in the hub and it should slip out enough to swap boots?
