Originally Posted by
hodrosS42001
Especially if you go from park to drive and floor it.. there is clutch lag not turbo lag.. which many people experience because they dont know any better. You need to be in drive and make sure you're actually engaging first gear.
What other gear besides 1st would be engaged in a DSG from a standstill? LOL There is actually both lags, the clutch lag you can learn to overcome by not slamming your foot down on the accelerator as fast as possible.....slow is fast here. But the turbo lag is real and there's nothing you can do about it. If you know what you are doing, and actually drive an S3, you can note the turbo lag not only from a stop but in corners as well. From the obvious feeling when the turbo kicks in to the boost gauge display showing no boost, only the oblivious or willfully obtuse would claim there is no turbo lag.
Sorry to bust your bubble.
hodrosS42001
You can ensure what gear engages by rolling in drive after having it in park or switching to manual mode and make sure its in 1st when the clutch engages.
I only (99% of the time) drive in manual/dynamic, there is no way to start the car off in anything other than 1st. Unless you are going to make the claim that the car can move itself 20ft on idle, in manual/dynamic with the display showing "M1" and NOT have the clutch engaged. If you are making that claim there is no reason to even respond to the claim as it is ridiculous on it's face.
The S3 is actually the perfect storm of DSG delay, turbo lag, and fly-by-wire throttle.
hodrosS42001
Many of the best B8 S4 DSG 1/4 times actually have been without launch control.
The problem with that is that the S4 uses a supercharger, not a turbo. So this fact actually adds nothing to this topic. A supercharger by design is incapable of lag since it is directly tied to the engine RPM.
