Results 1 to 7 of 7
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: B6 A4 ECS 2.0T FSI Coil Pack Conversion Kit
    The combustion event inside the cylinder must be carefully controlled to realize maximum power and efficiency. Upgrade to the 2.0T ignition coils to ensure your fuel mixture burns rapidly, thoroughly, and reliably, while enhancing the beauty of your engine bay.
    The stage I ECS Kit includes everything needed for the conversion: stainless steel hardware and a 2.0T Coil Pack Conversion Plate (3 color options). The stage II Kit adds aluminum Coil Pack Hold Downs (3 color options) to keep pressure on the coil pack—a simple and attractive solution to coils popping out of location.
    Spark It Up
    Fits:
    Audi B6 A4 1.8T (2002-2005)
    Jason
    Feb 03 2012
    Scranton, PA
    What is the difference between these and the hitachi e style coil packs?
    Sent from my iPhone using The gerbil that runs my mind
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by djsa4 View Post
    These are the latest revision coils. The Hitachi E style is considered obsolete now that the FSI coils are available. Though some people like the fact that the Hitachi E coils still bolt down. But our conversion kit offers coil pack tie downs in the Stage 2 kit which gives you the best of both worlds.
    Jason
    Established Member Two Rings insomniA4's Avatar
    Jun 28 2015
    thomaston, ct
    Is it recommended to run spark plugs a step colder with these if your on a tune running 20psi?
    04 a4 1.8t Q 6spd - podi boost gauge, 3" tp, forge tip, forge splitter, 034 race snub, h&r/bilstein suspension, tt225 injectors, apr 1+, southbend stage 2 endurance clutch, 17" voxx, s4 front bumper, treadstone fmic w/ custom piping
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by insomniA4 View Post
    It's generally recommended to run colder plugs with a tune. FSI Coil packs alone don't require colder plugs.
    Jason
    Jan 06 2009
    They do require running FSI plug gap though. 1mm IIRC.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by ADCS View Post
    Seems to be a debated topic. I run the FSI coils at the 1.8T OEM spec gap and haven't experienced any issues. If anything I believe the FSI coils can allow you to open your gap a bit for a larger spark. But don't quote me on that, I'd have to do some digging to refresh my memory to confirm.
    Jason
