I have a 2005 S4 B6 avant with 99,000 miles and been having high long term fuel trims (~ 14) and getting p1127 and p1129 codes after performing maintenance such as a new fuel filter, new coils and spark plugs. My question about the fuel filter (3 prong) is that from what I read, it also has the fuel pressure regulator within it because I cannot find a FPR on the fuel rail in the engine. If this is true, even though the fuel filter is new, could the FPR be bad inside it and causing extra fuel to leak through leading to both banks being rich (prior to maintenance fuel trims where fine). I had sprayed to original MAF with MAF cleaner which I thought could have damaged the MAF sensor for which I just put a new MAF in but still the furl trim problems. Short term trims are fine. The fuel pump also makes a winning noise and I cannot remember if it did that before changing the fuel filter but I know that a clogged fuel filter could cause fuel pump noises but fuel pumps in general will create a noise anyway. One thing that has not been done yet is changing out the oxygen sensors but I would not expect both sensors to go out at the same time causing both banks to go rich so I am looking at parts that can affect both banks. I also did the check for vacuum leak trick with carburetor cleaner and did not find any change in idle. Any thoughts?
