Results 1 to 6 of 6
    Jul 08 2015
    Wyoming
    Adaptive Air Suspension problem?
    11
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Make up a bucket of soapy water and rub it all over your struts, and lines reading them. If you see bubbles you have a leak there.
    Could just be a leak in the system, or a bad compressor. If you have had this problem for a while, then the compressor has been working overtime and could be on its way out.
    These problems are best fixed quickly before they compile.
    Please Drive Right
    Jul 10 2012
    buffalo
    most likely cause is a leaky front bag. sometimes parking the car on a higher level than normal will prevent the car from sinking overnight, but this of course is a side step to the problem and is only temporary. If this does fix the issue then you know you have airbag problems for sure. Fix it before you kill your compressor or park the car.
    1995 camaro with taurus SHO engine
    2001 audi a8 gutted because race car
    2009 chevy express 2500 duramax built 4L85E trans and tuned for around 400hp
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
    Jul 10 2012
    buffalo
    We have experienced this in the shop before. It is a pain in the ass to set the lift on a car when it is dumped to the ground. we have chalked it up to them being picky bitches sometimes. I would assume the control module knows it is below the lower limit (via ride height sensors) and does not always reset itself to try raising the car. It is possible that there is a thermal cutoff in the compressor but I do not know for sure.
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
    Jun 02 2008
    You can also park it over night in jack mode, that shuts off the self leveling. If you have a leak it will show the next morning. If it is still level it could just be a sensor like said above.
    Please Drive Right
    Jun 02 2008
    You can do the soap test to find the leak, but you will probably need to replace the strut.
    I think like $1500 for the OEM, lots of people go with Arnot rebuilt ones ($700) then send in your core for the next person.
    Please Drive Right
