OK folks, I know this is a given.. but I need to vent a little.
I hate doing brake work.. its always messy, and nothing every seems to be perfect.. stuck bolt, pads dont fit in the cage right, etc...
SO here we go.
Traded my truck for an a4 Monday. He says the radio works well enough, AC is cold, needs a new cat, and the driver side rear caliper needs to be replaced. Some weld in cats are in the trunk (they are), as is a set of pads, replacement caliper, and disk...
I fix the radio and ac controls (sticky from someone spilling soda in em.. probably from that overhead cup holder), and decide to tackle the caliper.
Who ever mounted the wheels used an impact wrench.. and went ape nutz crazy. My 220 lbs bouncing on the lug wrench didnt do a thing. Ended up beating the wrench with a hammer to imitate an impact wrench.. they finally break free.
Start pulling things off, things going smooth. Get everything off, swap caliper onto the fuel line (man it'd be sweet if that fitting spun instead of having to spin the caliper around it lol), parking brake reattached.. time for reassembly..
get things bolted back up, cage has powder coat in the holes so I have to chase them out or the bolts dont work (warning bells are starting to ring.. lets carry on). Get the cage bolted up around the new rotor.. makes me really miss my vw. The vw had a screw to hold the rotor to the hub while you were messing with the cage.. Made things lining up so nice and easy. ANYways.. get the cage bolted up, look at the rotor.. its now off center. Looks like the cage is a out of spec.. and the rotor wont line up with the center hub... no go.
Swap in old rotor to see if the off brand rotor is at fault.. nope.
Swap out the new cage with the old rusty one.. bam.. perfect fit. Slap .. it fits. got her bled and locked down tight now..
sorry.. had to vent. Box was marked Napa eclipse. Yeah, I know.. stick with OEM parts or a known entity, not store parts. Just figured you guys could use the heads up. The piston was perfect (which is good since the other piston was frozen), but that brake cage was so far out of spec that it couldnt even be made workable.
