Results 1 to 19 of 19
    Jul 02 2015
    Bermuda Dunes
    2006 S4 Transmission issues
    I recently purchased my first Audi and everything seemed great on the test drive and it drive perfectly when driving "normally". Once I owned it for a bit I tried to see what it had at a little harder throttle. If I got hard enough on the throttle it would red line in first and sound like it was slipping and would not shift into second, once I let off for a few and let the RPM's drop down it will either go back to normal or sometimes it will seem like it is in 3rd and the gear indicator just shows all gear highlighted (see pic). Any idea of what it could be or how bad that damage is would be greatly appreciated. I tried to search, but I'm either using the wrong search terms or just not finding the right thread. I haven't quite figured out where everything is on this forum yet.
    Jun 07 2013
    West
    Happened to me. That is limp mode and it typically means the transmission has lost communication with the ECU. Damage is unlikely. The problem is likely electrical. Get it to an Audi dealer.
    Jul 02 2015
    Bermuda Dunes
    Thanks, I was thinking it was some sort of limp mode since it goes back to normal when I restart the car. Do you remember what they had to repair/replace and how much it was roughly? The dealer here wants $160 just to look at it. I can take it easy in 1st and 2nd until I can get it repaired or save up for it.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Get somebody with vag com to scan it for you.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Jul 02 2015
    Bermuda Dunes
    I found a European repair shop that will check it for free I just have to make time for an appointment. They will definately have my business over the dealership.
    Jan 17 2014
    New Jersey
    When my car was still tip my trans went to limp mode once without a reason had to get it scanned with vag com. As i found out when i did the swap reason was trans filter all clogged up.
    Insta: luccamentone
    Jul 02 2015
    Bermuda Dunes
    I plugged my OBD II scanner in and got P0730 incorrect gear ratio
    Senior Member Three Rings blocke's Avatar
    Jul 26 2013
    1990 BMW 325i (sold), 2006 VW GTI (sold), 2006 A4 S-line (sold), 2014 Jetta SportWagen TDI
    Temecula, CA
    You need a VAG specific scanner.
    Performance: Fast Intentions 12" resonated cat back, ECS Snub Mount, JHM LTW Crank Pulley, JHM IM spacers, Optima Red Top, Dimple Oil drain magnet, 034 engine mounts,
    Suspension/Brakes: JHM LTW rotors front & Rear, Hawk HPS Pads, VMR V708's, H&R Sport springs, 034 strut mounts.
    Visual: Lamin-X on headlights, 20% tint , ZIZA city LEDs, Ziza License place LEDS, Interior LED conversion, R8 oil cap, 996 coolant cap
    Instagram: lockebrian
    Jul 02 2015
    Bermuda Dunes
    I understand VAG-COM scanners have more capabilities, but the one I have was able to read the code and reset the CEL. I'm still looking into a VAG-COM but haven't read up enough yet to know what model I need/want.
    Jul 02 2015
    Bermuda Dunes
    I got my Ross-Tech VCDS in the mail today
    So can anyone help me with what these codes mean? Thanks
    Thursday,06,August,2015,21:35:40:01549
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 15.7.0.1 (x64)
    Data version: 20150729
    www.Ross-Tech.com
    VIN: WAUGL78E46A181912 License Plate: JASON
    Mileage: 191070km-118725mi Repair Order:
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAUGL78E46A181912 Mileage: 191070km-118725miles
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8E2 910 560 A HW: 8E2 907 560
    Component: 4.2L V8/5V G 0030
    Revision: --H01--- Serial number:
    Coding: 0007771
    Shop #: WSC 22130 444 84210
    VCID: 2541A124ECE70B1605-8070
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 8E1 910 156 F HW: 09L 927 156 B
    Component: AG6 09L 4,2 MPI USA 0030
    Revision: --H01--- Serial number: 4121161
    Coding: 0000002
    Shop #: WSC 06335 000 00000
    VCID: 2A5B521885F9246E28-807E
    4 Faults Found:
    001840 - Gear Ratio Monitoring
    P0730 - 002 - Incorrect Gear Ratio - Intermittent
    Freeze Frame:
    Fault Status: 00110010
    Fault Priority: 0
    Fault Frequency: 11
    Reset counter: 40
    Mileage: 190073 km
    Time Indication: 0
    Freeze Frame:
    RPM: 4064 /min
    RPM: 3968 /min
    RPM: 1568 /min
    (no units): 66.0
    (no units): 102.0
    Temperature: 82.0°C
    T.B. Angle: 25.9°
    001921 - Shift Monitoring
    P0781 - 000 - 1-2 Shift - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 1
    Mileage: 190397 km
    Time Indication: 0
    009984 - Transmission Friction Element / Clutch A
    P2700 - 000 - Apply Time Implausible - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 16
    Mileage: 190670 km
    Time Indication: 0
    001922 - Shift Monitoring
    P0782 - 001 - 2-3 Shift - Intermittent
    Freeze Frame:
    Fault Status: 00110001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 190972 km
    Time Indication: 0
    Address 03: ABS Brakes Labels: 8E0-910-517.clb
    Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
    Component: ESP8 quattro H06 0120
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004902
    VCID: 2959AD1480FF2F7621-807C
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BM
    Component: A4 Klimaautomat 2832
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6DD199042797F3568D-5122
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 L
    Component: int. Lastmodul USA 0504
    Coding: 01023
    Shop #: WSC 65536
    VCID: 3B75675C2963ADE643-4B00
    Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
    Part No SW: 8E0 035 593 E HW:
    Component: SDAR XM
    Revision: Serial number: AUZ4Z7E9040485
    Shop #: WSC 00000 000 00000
    VCID: 2B55571C89033D66D3-517C
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
    Component: Airbag 9.41 H12 3840
    Revision: 91H12384 Serial number: 0036N001A033
    Coding: 0032607
    Shop #: WSC 98765 666 30530
    VCID: 3C7764407F6DAADE4A-8068
    Subsystem 1 - Part No: 8E0 910 339 B
    Component: BF-Gewichtsens. 002 0070
    Subsystem 2 - Serial number: 35Z1X
    Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
    Subsystem 4 - Serial number: 000000ÿ†6332DRB40285888E-ÿ†63
    Subsystem 5 - Serial number: 5888E-ÿ†6342DRB402920C1FPÿ†63
    Subsystem 6 - Serial number: 20C1FPÿ†6352ARB400AE9C8D5ÿ†63
    Subsystem 7 - Serial number: E9C8D5ÿ†6362ARB400A6679F-ÿ†63
    Subsystem 8 - Serial number: 6679F-ÿ†63729RB400D7564DVÿ†63
    Subsystem 9 - Serial number: 7564DVÿ†63829RB400D756BC ÿ
    Subsystem 10 - Serial number: 756BC ÿ
    3 Faults Found:
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Time Indication: 0
    01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Time Indication: 0
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 13
    Reset counter: 39
    Time Indication: 0
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0601
    Coding: 04141
    Shop #: WSC 06335
    VCID: 418915B44B8FC73619-4B00
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 982 C HW: 8E0 920 982 C
    Component: KOMBI+WFS 4 H14 0110
    Revision: 0110 Serial number: 00000000000000
    Coding: 0023261
    Shop #: WSC 22130 444 84966
    VCID: 2E535E08BA11484EF4-5122
    Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
    Coding: 0023261
    Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
    Part No: 8E0 959 760
    Component: Sitzmemory R2 F 0305
    Coding: 00002
    Shop #: WSC 00000
    VCID: 71E985743BAF17B6A9-4B00
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 J HW: 8E0 035 192 J
    Component: RNS-E US3 H71 0110
    Revision: 02S Serial number: AUZBZ7E2450219
    Coding: 0309637
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 27
    Reset counter: 219
    Time Indication: 0
    Date: 2005.02.10
    Time: 00:14:57
    Freeze Frame:
    Voltage: 12.60 V
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 48
    Reset counter: 219
    Time Indication: 0
    Date: 2005.02.10
    Time: 00:00:30
    Freeze Frame:
    Voltage: 12.60 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 219
    Time Indication: 0
    Date: 2010.03.25
    Time: 08:48:01
    Freeze Frame:
    Mileage: 655350 km
    Count: 608
    Clock: 21:28
    02446 - Disk Drive Mechanical Malfunction
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 5
    Fault Frequency: 24
    Reset counter: 143
    Time Indication: 0
    Date: 2015.07.03
    Time: 12:00:45
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BT
    Component: Komfortgerát T7B 3332
    Coding: 11836
    Shop #: WSC 06335
    VCID: 0407DCA0141D121E72-4B00
    Subsystem 1 - Part No: 8E1959801G
    Component: Tõrsteuer.FS BRM 0506
    Subsystem 2 - Part No: 8E1959802G
    Component: Tõrsteuer.BF BRM 0506
    Subsystem 3 - Part No: 8E0959801E
    Component: Tõrsteuer.HL BRM 0606
    Subsystem 4 - Part No: 8E0959802E
    Component: Tõrsteuer.HR BRM 0606
    6 Faults Found:
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    01573 - Alarm triggered by Door Contact Switch; Rear Left
    35-00 - -
    Address 55: Headlight Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
    Component: AFS 1 H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000019
    VCID: 285FA8109BF5167E3E-807C
    Subsystem 1 - Part No: 8E0 941 329
    Component: AFS-Modul links H03 0020
    Subsystem 2 - Part No: 8E0 941 329
    Component: AFS-Modul rechtsH03 0020
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0309637
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 27
    Reset counter: 219
    Time Indication: 0
    Date: 2005.02.10
    Time: 00:14:57
    Freeze Frame:
    Voltage: 12.60 V
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 48
    Reset counter: 219
    Time Indication: 0
    Date: 2005.02.10
    Time: 00:00:30
    Freeze Frame:
    Voltage: 12.60 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 219
    Time Indication: 0
    Date: 2010.03.25
    Time: 08:48:01
    Freeze Frame:
    Mileage: 655350 km
    Count: 608
    Clock: 21:29
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 24
    Reset counter: 143
    Time Indication: 0
    Date: 2015.07.03
    Time: 12:00:45
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 G HW: 8P0 862 335 G
    Component: FSE_255x BT H21 0190
    Revision: 00000001 Serial number: 00000000365378
    Coding: 0011877
    VCID: 3A7B6258765994EE58-5140
    End-------------------------(Elapsed Time: 07:01)--------------------------
    VCDS Release 15.7.0: SRI Reset
    Control Module Part Number: 8E0 920 982 C Labels: 8E0-920-9xx-8EC.lbl
    Component:KOMBI+WFS 4 H14 0110, Coding:0023261
    Operation: Please select an operation
    Channel Description Unit Current val. New val.
    02 Service Reminder Status 1 ---
    40 Mileage since Service miles x100 139 ---
    41 Time since Service Days 241 ---
    42 Min Mileage to Service miles x100 50 ---
    43 Max Mileage to Service --- --- ---
    44 Max Time to Service --- --- ---
    45 Oil Quality 1 ---
    46 Total Consumption --- --- ---
    47 Soot Quantity km x100 0 ---
    48 Thermal Load km x100 382 ---
    49 Min Time to Service Days 365 ---
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    Ross-Tech has a wiki page that list fault codes, that should help you with diagnostics. You have two problems:
    First one is the transmission fluid and filter needs to be changed. Drive for 2-3k and change the fluid again. Chances are is that it has never been changed.
    Second one is you're getting a low voltage fault across multiple devices. Either the battery or the alternator is going out. With the car being 10 years old, I would look at the battery.
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    I had this same problem on my a6 and many other people with this transmission. The solenoids go bad in the transmission and they cannot fully open the valves. It seems 2006 cars have the problem the most, maybe there was a bad batch of solenoids.
    I wouldn't drive it hard until you get the slipping fixed. You will grind the clutch packs down fast.
    Does the problem seem worse when the transmission is warm? 80˚C+?
    Jul 02 2015
    Bermuda Dunes
    Thanks JayDog747. I looked at the wiki page, but Audi terms are still like a different language compared to the ford's I'm used to working on. I'm hoping a battery and transmission flush will solve some issues.
    FormulaElement did you have to pull the trans to replace the solenoids? I'm pretty mechanically inclined but I usually avoid trans work lol. The problem happens anytime my foot gets into the gas, the Temps here are over 100 degrees ferenheit. I'll have to monitor the trans temp while driving and see if it changes when it's hotter. But even right out of the driveway of I give it too much gas it will slip. Right now I just keep it below ~3500 RPMS to keep it from slipping.
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    Valve body and solenoids are accessible under the car when you drop the trans oil pan.
    2013 Arctic White Allroad Premium Plus
    RIP 04 S4 Avant 2012-2017
    Mar 05 2012
    Mazda RX8 GT
    south florida
    ^^^^^ how much would a trans service that involved changing the solenoids run. Where can you purchase the solenoids?
    When i had a maxima there was a company who would moddify the trans Valve Body to allow faster and more crisp shifts, think they were called level 10 iirc, is there a mod or service which can be done to the S4 VB to allow faster shifting???
    B7 Sprint Blue Audi S4
    Few mods here and there
    Jul 02 2013
    406, MT
    New fluids labor and changing the solenoids would probably be around $1500+. You can do it yourself for around $900. The CTSC sells the solenoids, just make sure to get the right serial number off your transmission.
    Level 10 makes valve bodies for every car pretty much. You can buy one for your S4. There are other companies also, try google.
    Mar 08 2011
    Chicago IL
    Parts and valve body overhaul kits are available from Sonnax:
    http://www.sonnax.com/parts?utf8=%E2...rder=new&makes[]=VW%2FAudi&makes[]=ZF&types[]=Solenoid&commit=Filter
    Jul 02 2013
    406, MT
    I am currently doing the pressure overhaul kit from sonnax. I don't recommend anyone doing it unless your very mechanically inclined. The instructions arent a step by step and there is a lot of parts and pieces it doesn't even show And they will fall out when doing the overhaul.
    I consider it much harder than the timing guide job....
    Mar 05 2012
    Mazda RX8 GT
    south florida
    Quote Originally Posted by FormulaElement View Post
    let us know how it all works out. id love to hear what kind of results this gets.
