Originally Posted by
jayts
My crankshaft pulley went on Tuesday, just placed my order today, I only drove about 50 feet after I felt the power steering go out so no other damage.
I got quoted 5 hours labor from my indy shop, it would be really nice if someone new how to do this faster
Or if JHM could put up a DIY
I can post a brief DIY:
You want to do everything in the APR supercharger pulley install minus taking off the super charger pulley.
http://www.goapr.com/support/install...ley_30tfsi.pdf
APR has you install some longer bolts into the core support to help support it outward, i found you get even more room with them left out.
Remove the supercharger belt (16mm wrench).
Note: there is a white line on the stock pulley indicating i believe TDC, if you can, rotate till that is on top before proceeding.
Before removing the main serp belt you want to loosen the 8 crank pulley bolts (i did not fully remove them at this point). Mine were 10mm tripple squares not allen or torx, so make sure you have a few tools at your disposal just incase. You have to loosen them blindly as you cannot see into the pulley as the core support is in the way. I used a similar tool like this with a gear wrench because of the clearance.
There is a separate tensioner for the main serpentine belt, i used a 17mm wrench to release the belt.
Once the belt is off, remove the 8 pulley bolts.
The pulley will now come right off.
Reinstall in the opposite order.
Hope this helps any that want to DIY this.
