Results 1 to 8 of 8
    May 26 2015
    Philadelphia
    rattling noise while moving slowly
    went to DD to get coffee today and while i was moving slow through the drive through near the wall noticed a rattle sounds like chains? but once i go out to real driving it went away. any idea i thought it could be a heat shield but it was not.
    Veteran Member Four Rings a4_matt's Avatar
    Sep 19 2006
    Wanted: e30 calyso vert!
    Chicago
    I'm having a similar issue in my B8 A4 as well. Started hearing it a couple days ago but haven't figured it out yet
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Quote Originally Posted by b8sfour View Post
    Did you have loose change sitting in the ashtray? I could imagine that sound occurring if you were idling a little rough, and then disappearing when you started driving.
    The only other logical explanation is that your car is haunted.
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    loose brake clip or dust shield. Mine has been doing this for 2 years on the passenger side. Cannot pinpoint it. its like a light chain/metal scrape/bounce sound.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Get your engine and transmission mounts checked. Also, the caliper gap- sometime during brake checks, they will leave the caliper gap pretty open, causing a rock to get trapped.
    Tortoise A6
    May 26 2015
    Philadelphia
    yea i sometime hear it when i drive past other cars slowly leaving red lights. ill have to look closer
    Veteran Member Three Rings Mr.Tan's Avatar
    Sep 02 2014
    '01 GTI
    York, PA
    Quote Originally Posted by ENVē View Post
    I feel like im experiencing the same thing, except only when driving 60+ on the highway and when I slightly turn the wheel to change lanes. Its like a high-pitched metal scraping sound. Not present at low speeds around town.... no clue what it is, but its annoying.
    www.epautohaus.com for all your aftermarket performance parts, wheels & tires
    May 26 2015
    Philadelphia
    went chasing for the rattle today....couldnt find it. soo annoying.
