Results 1 to 7 of 7
    Established Member Two Rings mrw's Avatar
    Aug 20 2008
    RS5 Cab sold, 2009 A4 Avant 3.0 6mt swap-sold, 2021 Jeep 392, 77 Datsun 280Z V8 2017 S6-sold
    Delaware
    Are Rear Diff ratios different -A4 auto vs S4 manual
    Does anyone know what the rear diff ratios are in a 2009 avant 2.0 auto and a 2012 S4 Manual are? I need to know if the rear diff from the 2009 2.0 would work in the 2012 S4. I have found info on the B5, B6 and B7 but none on the B8. Thanks
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    I would suggest that you get the part number and check it on a site similar to this:
    http://www.jimellisaudiparts.com/pro...wd=&origin=pla
    If you are replacing the diff in an S4, I would go with the S4 sport diff for better handling.
    Veteran Member Four Rings bermudakid's Avatar
    Nov 02 2010
    Santa Barbara
    No they are not the same... ( I'll be back to insert my facepalm meme here <---)
    A4 gear Ratios, 6 speed automatic w/Tiptronic (2009-2012)
    1st4.171
    2nd2.340
    3rd1.521
    4th1.143
    5th0.867
    6th0.691
    Reverse3.403
    Final drive 3.517
    S4 Gear ratios
    Manual:
    1st: 3.667
    2nd: 2.158
    3rd: 1.52
    4th: 1.133
    5th: 0.919
    6th: 0.778
    Final: 3.68
    S-Tronic:
    1st: 3.69
    2nd: 2.24
    3rd: 1.56
    4th: 1.18
    5th: 0.92
    6th: 0.75
    7th: 0.62
    Final: 3.88
    Final drive has to be the same for the rear dif
    2011 A4 6MT - APR Stage II - Bang & Olufsen Aftermarket Sub - Eurocode HFC + Alu Kruez - 034 Trans Mount - S4 Brakes
    "Forget the "line" Get the real S"
    Instagram TPR.Visuals
    B6 Totalled - RIP
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by bermudakid View Post
    Just because the final drive ratio is different, doesn't mean the rear differential is different. ( I'll be back to insert my facepalm meme here <---)
    If they change the rear differential ratio with every combination of car/transmission, that means they'd have to also change the front differential ratio. It would be much simpler to keep those parts universal, and change the ratios at or before the center differential.
    I don't know the answer to the question, but knowing the final drive ratio doesn't necessarily lead you to the answer.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Dec 10 2013
    Borden, Ontario, Canada
    Usually A4 auto and all S4 models have the same diff ratios. (B5 knowledge here, i may be missing things)
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Feb 16 2019
    miami, fl
    does anyone know if the rear diffs are the same between auto s4's and auto a4's, even though the final drive differs?
    Jul 16 2018
    Atlanta
    Not sure what you mean by "are they the same though they are different". Same class, like 0BC?
    S4 with 0B5 DSG7 used normal diff 0BC code JKS with a 35:9 ratio or sport diff 0BF code (lots) with a 35:9 ratio.
    A4 with 0B6 ZF6 used normal diff 0BD code KBU with a 43:13 ratio
    A4 with 0BK ZF8 used normal diff 0BD code KBU with a 43:13 ratio or normal diff 0BC code KRR with a 43:13 ratio (KRR shows in ETKA, though the repair manual doesn't show a KRR allocation; the only 43:13 in it is KCC, but it has a different driveshaft flange diameter)
    0BF is the sport diff. 0BE is a stronger version of the 0BF for the A8 with V8 TDI and 0BL ZF8 transmission.
    No idea what's actually different about 0BC vs 0BD. I know I have a 0BD KBU with my 0B6 KXT in my '09 A4 2.0T.
