Results 1 to 13 of 13
    Established Member Two Rings 4kqlifer's Avatar
    Feb 25 2012
    Issaquah
    04 B6 S4 new owner with rough idle. Yes, I've searched. ;)
    Hey all,
    Just got a Dolphin grey tip 04 S4 that I love. I've owned Audi's forever with multiple 4kq's, an A4, A6, and Allroad. This year of S4 is the best looking of the lot (including the new ones) imo. The RS4 is the only one that I would want above the s4. Anyways, I got it and thought it only needed coilpacks so I took a risk. It ran fine and I only say the 0300 code when I got it with the Napa scanner. Well obviously I should have Vag'd it as it now has a rough idle at a stop. It runs great otherwise and has plenty of power. I replaced all the coil packs and plugs which made no difference. I had a buddy VAG it before I did the packs and plugs and I'm hoping it's not the cam tensioner. It doesn't really rattle like I've read with other forum posts and the power is there. I also have a super squeaky front right suspension. Like bed springs in Hugh Heffners house every time you go over a bump. I order the front control arm kit and hope it's the control arms only. So a long journey is ahead of me with this car but damn it's a fun car.
    Codes before the coil packs and plugs.
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Control Module Part Number: 8E0 910 560 C HW: 8E0 907 560
    Component and/or Version: 4.2L V8/5V G 0010
    Software Coding: 0007771
    Work Shop Code: WSC 25169 444 54350
    VCID: 254A75DAEFAE25093D9-5178
    11 Faults Found:
    16395 - Bank 1: Camshaft A (Intake)
    P0011 - 008 - Retard Setpoint not Reached (Over-Advanced) - MIL ON
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 002 - - MIL ON
    16685 - Cylinder 1
    P0301 - 002 - Misfire Detected - MIL ON
    16687 - Cylinder 3
    P0303 - 002 - Misfire Detected - MIL ON
    16686 - Cylinder 2
    P0302 - 002 - Misfire Detected - MIL ON
    16691 - Cylinder 7
    P0307 - 008 - Misfire Detected - Intermittent
    16689 - Cylinder 5
    P0305 - 002 - Misfire Detected - Intermittent
    16688 - Cylinder 4
    P0304 - 002 - Misfire Detected - Intermittent
    17924 - Intake Manifold Valve (N156)
    P1516 - 004 - Open Circuit
    16591 - Injector: Cylinder 7 (N85)
    P0207 - 004 - Circuit Malfunction - Intermittent
    18010 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    Readiness: 0000 0000
    Veteran Member Three Rings noob5's Avatar
    Dec 09 2007
    Have you done a throttle body adaptation via vcds?
    '13 allroad Monsoon | APR K04/hfc/downpipe/FMIC | H&R | 034
    '07 RS4 Imola | JHM 93/Stg4 clutch/Shifter trio/Intake spacers | KW HAS | 034 t-mount/linkage arms | Stoptech rotors/pads | Milltek DP's | ECS H-Pipe/motor mounts/rear diff mount
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    99.5 A4 2.8Q Volcano Mica
    02 S4 Santorin
    04 allroad 2.7T Alpaka
    10 Q5 Brllnt Blk
    Feb 25 2012
    Issaquah
    Quote Originally Posted by noob5 View Post
    No I have not. My next purchase is a VAG. I have to have a friend do it each time and it's not very efficient. Can you explain why?
    Feb 25 2012
    Issaquah
    I just looked it up and it does say that the TBA may be needed after a battery swap. I changed the battery last week. Hmmmm?
    Veteran Member Three Rings evolution2147's Avatar
    Mar 25 2012
    AZ
    You are going to want to get that timing code sorted out. This could be a little dangerous since you just bought it unless you got a good deal on it. It looks like the worst of the misfires are on bank 1 and are liking caused by the cam adjuster. Im not too familiar with the timing jobs on these cars but it may be possible to just replace that one adjuster without removing the motor.
    Mar 01 2015
    Norwalk ct
    Quote Originally Posted by evolution2147 View Post
    +1
    Will there be enough space to get to it and then correct the timing? This may well be an issue.. But if you frequent here its nothing new.
    "They say follow your dreams.....So I went back to bed."
    Feb 25 2012
    Issaquah
    Quote Originally Posted by Aundrealti View Post
    +1
    I saw the guy on YouTube that did the cam tensioner without removing the engine. It seemed like most were in disbelief but he did it. I got the car for a great deal so putting some money into it isn't too big a deal. Did I mention I'm in love with this car anyway? :) Any of you from the Seattle area and can recommend a shop that is familiar with these cars? I'm on the Eastside but I'm more wanting it done right.
    And huge thanks for the insights. I like that there is support on this site for the b6 s4's.
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Quote Originally Posted by 4kqlifer View Post
    Just because it doesnt rattle doesn't mean that a timing issue isn't present or going to come. My car didnt really rattle until it was freezing cold day and one day my timing guide broke without warning as i was driving.was almost as if it had ran out of gas
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Feb 25 2012
    Issaquah
    Quote Originally Posted by S4orgy View Post
    I heard a pretty pronounced rattle on startup yesterday. It didn't stay but that was the first time I heard it since I got it. It definitely makes you cringe.
    Mar 01 2015
    Norwalk ct
    It really doesn't
    Why? cus when you buy a b6 its expected, what makes you cringe is doing the timing job and then still get a rattle after a few 100 miles.. Then also realizing your cylinders are scored.. After you consumed oil that is..
    Save up, pull the motor and upgrade the timing stuff including the adjusters with jhm stuff... And since you got it cheap check your cylinder walls at the same time.. maybe if theres any scoring you could make one pull and get it all done.. then this will be all behind you.. then you could really enjoy your relationship.
    Feb 25 2012
    Issaquah
    It really doesn't
    Thanks for adding that. I assume that happened to you? I have been trying to figure how I'm going to attack this. I was looking at the Jhm intermediate kit. I was wondering if most shops will give you a warranty if they install the JHM stuff instead of genuine Audi parts? I'm also wondering the lifespan after its done? The upgraded kits make them last awhile I assume?
    Feb 25 2012
    Issaquah
    So I was looking at the injector #7 that was popping the code yesterday and trying to figure out if it was ok and whether the connections were good. Resistance was normal but the voltage was alittle higher on that plug. I was stumped. I just ordered a Vag so I figured I would just wait until I get it. Plug everything back together and the thing is idling amazing and the check engine went off!? Maybe the connector wasn't pushed down enough before? I drove it hard all over today and it hasn't popped back on and is running awesome. The question I have now is how long I should keep my fingers crossed? And damn I love how hard 2nd gear pulls.
    Feb 25 2012
    Issaquah
    So the check engine has popped on briefly here and there so I ordered another injector for the #7. I finally got the vag Com in the mail today so I pulled the codes. So the same 11 codes are still there from. when my buddy pulled them. I cleared all the codes and took it for a 70 mile trip out east of Seattle to see if the CEL popped on again. It ran beautifully and didn't throw any CEL. So I got home and plugged the Vag back in to see if any codes popped back on. The only one that came back was the intake flapper code. I assume 70 miles is enough to get them to show if they are going to show. The fact that the cam code or misfires didn't come back makes me think that they have been in there awhile and maybe the car already had that stuff fixed? It runs really well except for the rattle on startup. Wishful thinking maybe.
