Results 1 to 18 of 18
    Established Member Two Rings V01's Avatar
    Jul 24 2014
    OH
    Driver side puddle light not working.
    I was installing leds and did something to the driverside puddle light. All other lights are working. No blown fuses. Tried different bulbs.
    Any ideas?
    Thanks
    Aug 07 2014
    2020 Q8 Prestige,2023 S5 Prem+
    Stanwood, Wa.
    Did you try reversing the bulb in the socket? Check plug for voltage.
    Aug 04 2010
    Queenz/Westchester
    Quote Originally Posted by new2s5 View Post
    This, try flipping the bulb around
    Sent from my VS985 4G using Tapatalk
    Veteran Member Three Rings PlainOleS5's Avatar
    Apr 05 2015
    Ellicott City, MD
    Quote Originally Posted by shonseb View Post
    What they said! it does matter which way the plug goes in...even though it does fit both ways!
    2010 S5 Prestige | 6MT | Phantom Black | Sports Rear Diff | B&O
    Ziza LED Conversion/LP Lights | Windfire LED Projectors | 30% LLumar Pinnacle & Air Blue 80 WS | RS5 Grille
    Autostyle UK Floor Mats | AWE Touring/Non-Res DP | APR Carbonio | 034 Trans/Rear Diff | MRR GF9 19x10 ET25 | 255/35/19 Michelin Pilot Sport A/S 3
    Build Thread | IG
    Jul 24 2014
    OH
    Yeah, i tried that. I think i shorted something when i was removing the stock bulb. Fuse is ok though. the passenger door works too.
    Jul 24 2014
    OH
    Any other ideas?
    Mar 05 2014
    SF Bay Area
    put the working passenger light on the drivers side to be sure the light isn't bad
    Jul 24 2014
    OH
    Quote Originally Posted by Scumbucket View Post
    I tried a couple different lights and the OEM that was originally in there. None of them are working.
    Jul 09 2015
    MSP
    This just happened to me too. I've had my car a few weeks and tonight I was installing the led's. Front passenger door puddle light wasn't working. Figured the bulb was just burned out. Tried a known, good working bulb and didn't work. Swapped the whole light housing with the rear passenger door and still nothing. Would love to know what I can do to fix it.
    Aug 04 2010
    Queenz/Westchester
    This happened to my rear passenger door, anybody find a solution? It's definitely a short somewhere but I can't find it...
    Veteran Member Three Rings Brozee's Avatar
    Oct 12 2009
    Oxford, MI
    This happens on just about all cars. I always fixed it by simply getting out of the car. Locking it, unlocking it. Entering and they are reset/work.
    2013 S5
    APR Stg. 2+ Ultracharger, DSG, CPS | Full AWE Touring Exhaust | Roc-Euro Intake | H&R Coilovers | MRR GF6 | 034 Trans + Diff + Subframe Inserts | Apikol Rear Diff Mount | CR-15 | Full Eurocode USS Suspension | DEVAL CF Rear Diffuser | Adams Rotors / Akebono | Stoptech SS Lines | RS5 Grill | Tint | LED Interior, Reverse + Turn | HID Fogs | Escort Max 2
    Aug 04 2010
    Queenz/Westchester
    Nope didn't work
    Oct 09 2008
    Check for voltage
    The Awesome™
    Aug 04 2010
    Queenz/Westchester
    Quote Originally Posted by Brozee View Post
    After a couple of attempts, this worked. All lights on and bright!
    Thanks!!
    Sent from my Galaxy S6+ using Tapatalk
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    Thanks!!
    This happened to me too when I installed mine. Finally was just frustrated and gave up for a few days and then they fixed themselves. Very strange, but it does work!
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
    May 01 2020
    Orange County, CA
    Confirmed, they fix themselves! Just installed mine last night, the last one didn’t work. But this morning everything is working perfectly!
    Active Member One Ring OOOTHATQ5's Avatar
    Jan 12 2021
    2015 BMW F800GS
    Fife/WA/USA
    Just did the interior led swap and had the same thing happen! First door didn't work, finished the rest and they all worked great. Jumped on here to search for this issue and went back out after reading to see. Everything working as it should.
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    The puddle light circuitry automatically turns off after some period of time. Close and then open the door (with or without the light installed, don't short the wires) and you will find things should be working again. BTDT.
