Results 1 to 8 of 8
    Active Member Two Rings 2006a42.0T's Avatar
    May 27 2015
    2000 Audi A4 1.8T Avant
    Green Bay, WI
    Lightbulb (Twin Turbo) A4 B7 2.0T Project Idea
    I was wondering if a twin turbo set up would ever be possible on a 4 cylinder. Would it work if I made two exhaust manifolds one for every 2 cylinders then had two separate mounts for both turbos? Anybody have any ideas or suggestions? Im open for anything right now. This is NOT going to be two huge turbos, but it is going to be 2 K04's. I just wanted to do something different, and still have it functionable. Also about this set-up, how would I would I avoid the huge turbo threshold(spool time) because I'm not really worried about lag. Thanks.
    Feb 21 2012
    Porsche Cayenne Turbo, 2010 Ducati Multistrada 1200s, 1991 Toyota MR2 Turbo
    Northern California via NYC
    Why not just replace your existing turbo with a better $$ one like a garrett GT series- quicker spool yet larger compressor and be done. If you divide your exhaust gas by 2, your turbos will spool slower anyway.
    Apr 10 2013
    hamilton
    if your going the custom fab route, instead of twin turbos think more of a compound turbo set up. small turbo feeds the giant to spool it quicker. 2 k04's would spool horribly
    Oct 22 2014
    Charlotte, NC
    VW has been selling twin turbo setups for 4 cylinder diesel engines for years. It started out on their transporter vans, but the technology is expanding. They aren't cheap, either. The wholesale price for a new twin turbo unit is over 800 Euros.
    www.HansAutoParts.com - Over 7000 Parts for VW and Audi Cars.
    Aug 26 2005
    Using 2 very small turbos each driven the 2 exhaust ports would work. A setup like this would be complicated, but the two smaller turbos would spool up faster than a single unit. This is what BMW does with the 335i inline six, with 3 exhaust ports per turbo. Twin scroll turbos would be best. The only justification for a setup like this would be to minimize spool up lag. If you are not concerned with turbo lag, then a single unit is better.
    Vorsprung durch Technik
    Veteran Member Four Rings tchuck's Avatar
    Apr 11 2010
    '04 A4 1.8T Avant tip
    Portland, OR
    Personally I'd like to see full boost at idle.
    ŠTimtronic
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Quote Originally Posted by tchuck View Post
    then get a supercharger lol
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Oct 13 2009
    Other Broken Vehicles
    Farmington Hills, Michigan
    A few guys did compound set ups on 4g63 engines where you would see a benefit. As stated above you would be better of using larger frame divided turbine housing unit instead of 2 identical smaller units.
    (\_/)
    (o o)
    00 Laser Red "stage III" S4: Sold
    04 Moro Blue S4 6MT: Sold
    01 Allroad 6MT: Sold
    06 A4 Avant 6MT
    09 C63 P30
