Results 1 to 9 of 9
    Mar 24 2012
    Replacing ECU with IMMO-disabled unit from Reflect Tuning - what's required?
    New to Audi's and VAG-Com, so this is probably a dumb noob question, but-
    I'm replacing my flaky ECU (bogus cam faults, fan running when engine off, etc) with a unit from Reflect Tuning (IMMO-disabled, Stage 1). I've reviewed the articles on R&R'ing the ECU, but I haven't found any tech docs on what to do after the replacement ECU is installed.
    The little I've found about replacing the ECU talks about dealing with the IMMO. My replacement has the IMMO disabled, so that doesn't apply. So what else do I need to do? I understand that the ECU stores the VIN, so I assume I'll have to program the VIN into the new unit? (I've got Ross-Tech's VCDS, but haven't used it yet). Does the ECU decode the VIN to determine the engine details, or do I have to load other parameters? (stock '05 A4 Cabrio - no mods other than this tuned ECU)
    Is there a tech doc that details the VAG-Com part of R&R'ing the ECU?
    Feb 17 2004
    Liberty Hill, TX
    the only thing that's actually required is to set the soft coding of the new ECU to match your old one. VIN setting can't be done via VCDS but isn't required for normal operation.
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Jun 30 2008
    Erie, Pennsylvania
    If you wanted the VIN to match, you might be able to do the IMMO "used ECU swap" procedure anyway. Part of that procedure is to push the VIN from the cluster to the ECU. But whether it would work (or screw something up) would depend on how the IMMO defeat is done. That would be a question for whomever did the IMMO defeat.
    But I wouldn't even bother. It would be unnecessary messing about with important things. As long as the car runs and the IMMO light isn't flashing, I'd leave it alone.
    Aug 26 2005
    If the fans are running with the car OFF, check for water inside the ECU box.
    Vorsprung durch Technik
    Mar 24 2012
    Quote Originally Posted by Matt Devo View Post
    Would that be the "Software Code" section described in this Ross-Tech doc - Recode Module ?
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by jeffeverde View Post
    correct. write down the code from your current ECU, then recode the new ECU to match.
    Veteran Member Three Rings jaydeff's Avatar
    May 05 2013
    parts
    Orange County, CA
    With the immo defeated it should be plug and play with no extra steps required.
    2002 A4 3.0 6MTQ Crystal Blue Metallic
    2010 A6 3.0T Prestige Avant Night Blue Pearl
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    if you wanted it to be perfect you could copy your ecu's 95040 and write to the new one in boot mode. now your immo works and vin matches. But with immo off you will never notice anything wrong unless someone tries to steal the car ha.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Aug 26 2005
    The ECU will learn the new VIN from the cluster by entering the Login code in login II, then going to channel 081 and entering the login code there again in Basic Settings. IIRC, the login II is 13682 or similar.
