Results 1 to 22 of 22
    Jun 02 2014
    United States
    19in Wheels on B7 S4 Avant with stock suspension?
    Cant really find a definite answer to this, but can I fit 19in wheels on my B7 S4 Avant with just my stock suspension? Not interested in doing anything to the suspension but would like the look of bigger wheels. What does that do to the ride also?
    Senior Member Three Rings 98champ's Avatar
    Jun 30 2009
    '01 Silverado toy hauler, too many skis and a couple of wakeboards
    Amesbury, MA
    Yes they will fit. Ride quality will suffer a little bit depending on what size tire you go with. 235/35/19 will keep the speedo the same as stock wheels but you'll definitely feel more of the road with them. Also, slower acceleration with 19's as well.
    I haven't looked through in a while but I believe there's at least a sedan if not an avant with 19's and stock:
    http://www.audizine.com/forum/showth...=wheel+fitment
    His: 2005 Brilliant Black // Hers: 2009 A4 2.0T Brilliant Red
    Yellow Fogs / 6000k Headlights / Magnaflow Catback Exhaust / Hotchkis RS4 Sway Bars / Sterns End Links / JHM Short Shifter Trio / RS4 Shift Knob/E-Brake/Pedals / OEM 19" RS4 Wheels
    Active Member Two Rings LaKi's Avatar
    Feb 18 2014
    1999 Audi A4 B5
    Ljubljana, Slovenia
    Sure u can, i have it on B6... ET29 and 235/35 at front and 245/35 at rear... have some rubbing problem with rubbing but i got used to it..
    Speeding is a little bit slower but not that bad.. ride quality is quite same as on 18"...
    Jun 02 2014
    United States
    Interesting. So would it be best to go with 18s for just bit of a bigger wheel without too much change in acceleration and speedo?
    Jun 02 2014
    United States
    Also, I see that sedan you were talking about. It says under Fender Mods, Front half rolled. What does that mean?
    Jun 30 2009
    Amesbury, MA
    If you run your fenders on the inside of the front fenders you'll feel there's a lip. If you then go to the back you'll feel it's almost flat vertical. Fender rolling is taking that lip and rolling it up to the fender to make a little bit more clearance for wider/lower offset wheels.
    Jun 02 2014
    United States
    Gotcha. Thanks for explaining that. What is the process to do that? Would that be something that is mandatory in order to run 19s on a stock suspension?
    Jun 30 2009
    Amesbury, MA
    Nope, it's not mandatory. It all depends on how crazy an offset that you are looking to run. If you're looking for your wheels to be completely flush with the fenders and you live in a crazy bumpy area you might want to have them done/do them yourself. But on a stock suspension you shouldn't have to worry about it at all. I'm on stock suspension with B5 perch springs and run a really wide wheel (RS4 wheel) and I don't have my fenders rolled. My last B5 was lowered and I needed my fenders rolled and pulled out a little. All depends but stock you don't need to worry about it.
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    You can do it, but it won't look good:
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
    Jun 02 2014
    United States
    Well that's subjective.
    Veteran Member Three Rings Das Audi's Avatar
    Oct 14 2009
    Brampton
    I run 19's with the B5 front spring perches to drop the front and a touch
    AKA: fuzzy_onetoo
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Quote Originally Posted by Das Audi View Post
    That looks much better. There is just too much butt sag with the OEM suspension otherwise, which is exacerbated by the big wheels with small tires.
    Jun 02 2014
    United States
    Oh yea, that looks great! So what is a front spring perch?
    Oct 14 2009
    Brampton
    The spring perch sits on your front OEM shocks holding the coil spring. When using the B5 perches they allow the springs to sit lower thus dropping the front end by about 5/8". It is just enough to make the car look better without going the the expense of coilovers or lower springs.
    AKA: fuzzy_onetoo
    Jun 07 2013
    West
    Quote Originally Posted by nnnick View Post
    you can do it, but it won't look good:
    my eyes - horrible - burn the car and driver for that fender gap - needs a drop - 4x4 - doesn't look good
    Jun 07 2013
    West
    That looks excellent! The car looks ready to take on anything and the whole package works. Beautiful.
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    Das Audi, your Avant looks gorgeous, whose wheels are you running and at what width & et?
    OP, b5 perches apparently won't work with after market struts, should you choose to get into an adjustable strut down the road. http://www.audizine.com/forum/showth...s-or-Coilovers
    Jun 02 2014
    United States
    I see. That sounds like a great way to fix that fender gap. Thanks for letting me know. BTW, like that Avant! I got the same but in Dolphin Grey. Looking to purchase a Miltek exhaust here real soon and those are the same wheels I want to try to pick up. Those suckers are expensive though.
    Senior Member Three Rings joe@dubaudi.com's Avatar
    Mar 21 2010
    B7 S4 Avant / 2014 Allroad / 2015 Q7 TDI
    Point Pleasant NJ
    Oct 14 2009
    Brampton
    Quote Originally Posted by s4ski View Post
    Thanks...............I am happy with the look too...............Forgestar F-14s with the brushed finish 19x8.5 ET 38 running a 235/35/19 tire
    AKA: fuzzy_onetoo
    Jul 01 2013
    Anchorage, AK
    Thanks for info, I gather no rub?
    Oct 14 2009
    Brampton
    Correct.......never any rub
    AKA: fuzzy_onetoo
