So about a month ago I ordered a brand new OEM bluetooth kit off of eBay...
Post for Auction
So when I first installed it and went to code it in VCDS the initial soft coding was 0000000. If you want to see what the coding should be here is the link to the ross tech wiki...
http://wiki.ross-tech.com/wiki/index...ne_Preparation
So initially I decided to code the bluetooth module as follows: 0011877. The two sevens are both digits for the language setting of "US English" The problem was that the code kept getting rejected. I then emailed the seller who is from the UK and he told me to code it 0011822. The last two digits (the 2 and 2) both represent UK English. Magically the coding worked. My question is why does the module only accept coding with UK English and not US English. I will admit a that a British accent sounds cool but thats beside the point. My question is there something I can do so that I will be able to code it with "US English" instead of "UK English"?
