Results 1 to 9 of 9
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Brake Fluid Recommendation?
    Hey guys,
    Which brake fluid should I use for my stock 1.8T b5? There are so many choices online but I just want to use something that can give great pedal feel and can take abuse from heavy braking since I live in a densely populated area with a lot of traffic. I am replacing the rear calipers and going to do a flush so I am going to need 2 liters of it. Thank you.
    Nathan
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
    Dec 03 2014
    1999 Audi A4 Quattro Avant 1.8t 1998 BMW 328iC 1986 BMW 528e
    United States
    I'd go with any synthetic DOT4 compatible fluid. I usually use Valvoline. I used to use ATE super blue and super gold, alternating between them so I could tell when I had flushed enough. Super blue is hard to come by now. Most retailers stopped selling it since it is no longer legally distributed in the US. Super gold is the same fluid.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Motul RBF600
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Apr 26 2010
    North Jersey
    Quote Originally Posted by richardodn View Post
    I was reading about it. I believe ECS still sells the blue, on other forums they say the blue is not good for seals on the 2000 & newer Audi's is this true?
    Quote Originally Posted by LINDW4LL View Post
    Motul RBF600
    Can Motul RBF600 last for 2-3 years? Its a racing brake fluid so I'm not sure how long it can stay in the system for...
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Pentosin Super DOT4 is good stuff. Unless you're taking the car on track days, I wouldn't waste my money on racing brake fluid.
    The boiling points are more than sufficient for daily driving, even in "heavy traffic"
    From Pentosin's Data Sheet:
    Boiling Point ≥265°C/≥509°F
    Wet Boiling Point ≥165°C/≥329°F
    Compare that to the boiling points of RBF600:
    Dry boiling point 312 °C / 594 °F
    Wet boiling point 205 °C / 401 °F
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Apr 26 2010
    North Jersey
    Quote Originally Posted by fR3ZNO View Post
    I was reading about that one on ECS. Looks like it will best suited for my needs..
    Dec 03 2014
    United States
    Here are the specs for the Valvoline Synthetic.
    Dry Boiling Point, °F (°C) min 446 (230)
    Wet Boiling Point, °F (°C) min 311 (155)
    It's a good fluid and has good local availability.
    Another good locally available fluid is Prestone Synthetic
    Minimum Dry Boiling Point 510°F (266°C).
    Minimum Wet Boiling Point 311°F (155°C).
    If you plan on ordering fluid, go with the Pentosin.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Veteran Member Four Rings bhusted's Avatar
    Sep 11 2011
    B5 A4 4.2L V8
    Kirkland, WA
    For a daily, there is no reason to buy fancy brake fluid. I usually use Valvoline synthetic. It can be found locally and reasonably cheap. The biggest thing about brake fluid is to only use fluid from a sealed container. The fluid is hygroscopic and readily absorbs water. I live in a particularly damp climate and like to flush my brakes annually.
    | B5 4.2L V8 Quattro | Tein S-Tech | O.Z. Ultraleggera 18x8 | Stabila Course 22mm rear swaybar | Agency Power WRX swaybar links | S4 front brakes | A8 rear brakes | FX-R HID projector retrofit | Fog projector retrofit | RS4 Grill |Aero wipers |
    Dec 10 2011
    CLT | MKE
    Yes, I was a bit confused about OPs question as stock fluid is beyond sufficient for driving in traffic.
    Sent from my iPhone 6 using Tapatalk
    -Hayden
