Results 1 to 10 of 10
    Veteran Member Three Rings VroomTT's Avatar
    Nov 21 2013
    SE FL
    Vacuum Hose Routing Diagram
    I've searched AZ and beyond with no luck...
    Anyone know where this can be found? Or have the ability to pull it up and post?
    I'd like to get a better understanding of how everything works together and start analyzing what can be removed or improved
    Veteran Member Three Rings jvitelli17's Avatar
    Apr 15 2013
    2000 Audi S4 STOCK :)
    Meriden, CT - Warwick, RI
    can't help with diagram but x2 for this!
    06' | JHM 93 Tune | Piggies | Custom Magnaflow 2.5" x-pipe non-res | ECS Solid MM | Apikol Snub | JHM Intake Spacer | K&N Drop-in | NGK BKR6EIX| 5W-30 Castrol - SOLD BUT NOT FORGOTTEN!
    00' | STOCK (for now)
    VAG-COM 12.12.0
    Nov 21 2013
    SE FL
    Quote Originally Posted by jvitelli17 View Post
    I've been searching repeatedly, with no success. Somebody has to have this somewhere...
    Nov 21 2013
    SE FL
    Bumping to the top
    I'm seeing this as a re-occurring theme in more and more threads... Who can help us out???
    Sep 29 2014
    Berwick NS
    I don't have a routing diagram, but I have component location diagrams. I didn't upload them all because I am too lazy, this is the essentials.
    Here are the common vacuum connections in engine bay: Look at the Black Arrows for connections
    #4 in this image
    1 - Evaporative Emission (EVAP) canister purge regulator valve N80
    2 - Mass Air Flow (MAF) sensor G70 with Intake Air Temperature (IAT) sensor G42
    3 - Connector console
    Pin assignment
    Assignment of holder for connectors (right side)
    4 - Valve 1 for camshaft adjustment N205
    Rear view
    5 - Camshaft Position (CMP) sensor G40
    Cylinder bank 1
    Rear view
    6 - Engine coolant temperature (ECT) sensor G62
    At coolant pipe behind cylinder head, bank 1
    Rear view
    7 - Fuel supply line
    8 - Throttle valve control module J338
    With Throttle drive (power accelerator actuation) G186 , Angle sensor -1- for throttle drive (power accelerator actuation) G187 and Angle sensor -2- for throttle drive (power accelerator actuation) G188
    Rear view
    9 - Oil pressure switch F1
    Rear view
    10 - Camshaft Position (CMP) Sensor 2 G163
    Cylinder bank 2
    Rear view
    11 - Connector console
    Pin assignment
    Connector console beneath coolant expansion tank
    12 - Valve -2- for camshaft adjustment N208
    Rear view
    13 - Engine Speed (RPM) Sensor G28
    In transmission housing above ring gear
    14 - Ignition coils with output stages
    Cylinder bank 2
    15 - 3-pin connector
    For Knock sensor 3 G198
    For Knock sensor 4 G199
    Front view
    16 - Secondary Air Injection (AIR) Solenoid Valve N112
    Front view
    17 - Intake Manifold Change-Over Valve N156
    Front view
    18 - 3-pin connector
    For Knock Sensor (KS) 1 G61
    For Knock Sensor (KS) 2 G66
    Front view
    19 - Ignition coils with output stages
    Cylinder bank 1
    20 - Secondary Air Injection (AIR) Pump Motor V101
    Installation location of Fuel Pump (FP) Relay J17
    Position - arrow 1 - on 9-position relay carrier on left of drivers footwell.
    1.1 - Coolant Circulation Pump Relay J151 (hot countries only)
    1.2 -Not used
    2 -Secondary Air Injection (AIR) Pump Relay J299
    3 -Motronic Engine Control Module (ECM) Power Supply Relay J271
    4 -Relay for automatic transmission
    A -Engine electronics fuse S282
    B -Secondary air pump fuse S130
    C -Not used
    1) 6-pin connector for Heated Oxygen Sensor (HO2S) G39 and Oxygen Sensor (O2S) Heater Z19 before catalytic converter, bank 1
    2) Connector for starter (terminal 50) and generator
    3) 2-pin connector for camshaft timing control, bank 1
    4) 4-pin connector for Oxygen Sensor (O2S) Behind Three Way Catalytic Converter (TWC) G130 and Oxygen Sensor (O2S) Heater 1 (behind Three Way Catalytic Converter (TWC)) Z29 , bank 1
    Intake Manifold front
    1 Vacuum unit for intake manifold changeover
    2 Knock Sensor (KS) 1 G61
    3 Knock Sensor (KS) 2 G66
    4 Intake Manifold Change-Over Valve V156
    5 Secondary Air Injection (AIR) Solenoid Valve N112
    6 Knock sensor 3 G198
    7 Knock sensor 4 G199
    1) Valve -2- for camshaft adjustment N208
    2) Camshaft Position (CMP) Sensor 2 G163 , cylinder bank 2
    3) Oil pressure switch F1
    4) Throttle valve control module J338
    5) Engine coolant temperature (ECT) sensor G62
    6) Camshaft Position (CMP) sensor G40 , cylinder bank 1
    7) Valve 1 for camshaft adjustment N205
    Leak detection pump (LDP) V144
    Last edited by c0ntract_thrill; 08-10-2015 at 09:24 AM. Reason: added more diagrams
    Nov 21 2013
    SE FL
    Those are a big help, thanks c0ntract!
    Gotta ask, Where are these from?
    Sep 29 2014
    Berwick NS
    Quote Originally Posted by VroomTT View Post
    The Bentley
    Nov 21 2013
    SE FL
    Quote Originally Posted by c0ntract_thrill View Post
    The Bentley
    Gotcha. I was kinda surprised this hasn't been vetted out on here already. Flow diagrams are so readily available for 1.8t's and 2.0t's.
    As I learn more about how everything functions on the 4.2, my aim will be improving/deleting. Starting with the flapper hose and following it all back as much as possible. Several of the mini hoses are ready to crack, so tackling it all at once is the plan.
    Sep 29 2014
    Berwick NS
    There are a few audi sites that are more technical than here that have hosted some information.
    Regardless, if you're looking for detailed information a Bentley is a must.
    Nov 21 2013
    SE FL
    I also just noticed this in my S4...
    I wish mine wasn't all messed up, but at least it's readable. Would love to replace it with a new one.
