Well, I now have almost 51K miles on my car. I had the P0171 popping up for about the past month and a half or so. I took my car in for the fuel rail recall with the CEL on. When I went to pick it up I asked about the code and what they found. Well, the dealership said they didn't find anything, that I didn't have a code. Well I pulled out of the dealer, shifted from first to second and the CEL came on. I took it back to them and they said I had a code for clogged intake (I did download my car and it was there). They cleaned my intake and then told me the car was good to go. I tried to pick it up again. I was sitting just idling and then the CEL came on again. Went back in and told the dealership it was back. They downloaded it again and it had the P0171 just like before. They couldn't reset the code at the time (it was the service advisor doing the download not a tech). So they said it was ok to drive, but I needed to come back at a later date. The english speaking service advisor was out on vacation (I'm in Italy). I told them no problem, I would just download and reset the code myself. So, when I got home this is what I had:
3 Faults Found:
7804 - Position Sensor for Intake Air Regulating Flap
P10A6 00 [032] - Signal too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 81525 km
Date: 2000.00.00
Time: 00:00:00
7811 - Adaptation of Intake Air Regulating Flap
P10A7 00 [096] - Clogged/Dirty
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 81525 km
Date: 2015.06.10
Time: 17:12:39
6208 - Fuel Trim; Bank 1 (Mult)
P1128 00 [236] - System too Lean
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 81526 km
Date: 2015.06.10
Time: 17:16:30
I reset it and then 3 days later it came back with this:
2 Faults Found:
P1128 00 [237] - System too Lean
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 81688 km
Date: 2015.06.13
Time: 15:41:15
6212 - Fuel Trim; Bank 2 (Mult)
P1130 00 [100] - System too Lean
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 81688 km
Date: 2015.06.13
Time: 15:41:29
I have an appointment to take my car back next week. Any ideas on what is wrong? I read on alldatadiy and it ranged from fuel filter to maybe a fuel pump. It could be other things, but I didn't go to far into the troubleshooting that it had on there.
