Page 1 of 8 123 ... LastLast
Results 1 to 40 of 289
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    My PLM Heat exchanger Kit review **PICS
    I ordered a PLM Heat Exchanger to give it a try, the kit seemed real solid and built well so I bit the bullet.
    I didn’t have time to do crazy testing as with 3 little kids I don’t get much time to work on my car now. I decided to just do surface temp measurements to see how effective the exchanger is working.
    The main difference from this kit from the others is that it still utilizes the stock coolant loop, not a divorced system. After looking at diagrams and doing testing, there is very minimal movement of coolant from the main coolant loop from the supercharger loop. Having the system not divorced you can keep an eye on the coolant levels and also not have to worry about un foreseen leaks.
    Installation was relatively easy; there were no instructions included. It was not too hard to figure out what went where. The only problem I ran into was figuring out what hoses went where, as they included ones for the b8.5 that aren’t used. I will be writing a DIY how to install this kit, I just didn’t want to clutter it in this post at the moment.
    Overall I am more impressed with the kit that my original intentions, the quality and the fit was spot on. Im glad there is a cheaper alternative out there now.
    PLM told me they will be doing a special GB for this kit, I should have more info on it soon from them if there is a lot of interest. PM me as forum rules don't allow me to post info. The price will blow your mind, limited to only 10 kits.
    The kit arrived very nicely packaged, double boxed.
    The Heat Exchanger package comes with all the hoses and stainless hardware along with factory clamps. Even a drill bit for drilling the mounting holes in the support.
    The Heat Exchanger is built really well, has nice clean welds. It even has a bracket on it for an ADS cooler.
    The Coolant Reservoir is really nicely built, clean welds and black anodized. It comes with all the hoses for a b8 or b8.5 install.
    All the Hardware is stainless and with factory clamps and brass barbs.
    I painted the Heat Exchanger black with some Eastwood Radiator Paint
    Pic of Res installed
    Heat exchanger installed, I reused my old protection screen I had from the stock HE/radiator.
    Here are my temp measurements:
    Stock HE after driving 30 miles
    Coolant temps on my p3 gauge was 199-200F ambient was 68deg.
    Temp at the point where the loops connect
    Temp at the stock HE
    I did 3 hard pulls and re-measured the temps
    These are the measurements done after the PLM HE install.
    Note the ambient is 8degF less at the time, The Coolant temps now ranged in the 196-200 range, I never saw anything less than 199F with the stock HE, so there is more air getting to the stock radiator I presume also now as the HE is not pressed against it.
    Yea I know I need more coolant 
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Feb 13 2004
    S Ã C, CÃ*
    Post cont:
    After 3 hard runs on the same stretch of road.
    Sep 30 2009
    b
    looks like a quality piece
    so the benefit of this would need to be measured under greater/sustained stress?
    Nov 30 2010
    Anchorage, AK
    Looks nice, and seems to have demonstrable benefits.
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    The biggest challenges I saw stock were with ambients over 80'F and idling or slow speed then jumping on the throttle. The coolant loops in the SC get really hot from heat soak with little air movement. It will be interesting to see how much the aftermarket cooling upgrades help there.
    If you have VCDS, log the IAT.
    Thanks for the pix and temps recorded.
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    nice
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Senior Member Two Rings Ek9max's Avatar
    Feb 14 2015
    Calgary/Alberta/Canada
    So judging by the temp readings it seems to be working great right?
    I would think the iat's would also see a good improvement.
    As good as the competition you think?
    2010 Ibis White Audi S4 Prestige, Sport Diff, DSG, Red Nappa, Navigation, B&O, 3G MMi, CF Inlays
    APR Stage 2+ DP V4.0, APR TCU tune, Stassis Touring Exhaust, Kohlefaser Luft-Technik Intake System, PLM HX/Res, H&R OE Springs, Bilstein Sport Shocks, Akebono Brake pads, 20x9 ET38 Verde V99 Axis, Falken FK453 255/30/20, S-Tronic Shift Knob Conversion, ECS Ziza Master LED interior update.
    Jul 21 2004
    South Florida
    Thanks for taking the risk and trying it. I think I agree with you about going with a non divorced system. I like those benefits as well. Let us know how it holds up for you.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Sweet.. Good job!
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Feb 14 2015
    Aw hell. Ordered one up.
    Feb 13 2004
    S Ã C, CÃ*
    There are 7 spots left for the special purchase.
    Feb 14 2015
    Quote Originally Posted by infinkc View Post
    At the new group buy price. I couldn't resist.
    Veteran Member Four Rings mojangles69's Avatar
    Jun 03 2013
    2022 BMW X3 M Comp / 2017 Porsche 911 S / 2008 Audi A6 3.2 Wagon / Magic Carpet / Camel / Donkey
    Charlotte / North Carolina
    Nice write-up, OP! Nice job and glad it is working out for you. Please keep us appraised of how it holds up!
    2017 RS7 Performance - Sepang Blue - Performance Design Selection Package w/ Mercato Blue stitching and blue twill in interior carbon fiber components - APR Stage 2 w/ Militek downpipes and exhaust - Aquamist Methanol Kit - Custom Roc-Euro Intake - KW Adjustable coilover springs - K40 Radar/Laser System
    XPEL Ultimate, Ceramic Pro & Apex Huper Optik window tint
    IG
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Waiting for mine
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    where can i order with GB pricing
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Aug 03 2014
    Queens
    Read the full review. Infinkc states it in his post.. I took the plunge and got one myself.
    Previous
    Nov 05 2006
    Fair Lawn
    Quote Originally Posted by DGVR6 View Post
    am i losing my mind? i cant find it in this post anywhere
    Aug 03 2014
    Queens
    Quote Originally Posted by richib86 View Post
    No lol, you just probably over looked it as it wasn't detailed. Just PM Infinkc.
    Previous
    Feb 14 2015
    Ya Just PM Infinkc. pricing is pretty awesome if the product lasts.
    Aug 03 2014
    Queens
    Just received the goodies.. I'll be ordering a intercooler pump to go along with it once I'm ready to install.
    Everything's seems to be built with quality from what I can see. Happy so far.
    Previous
    Feb 13 2004
    S Ã C, CÃ*
    what pump were you thinking of using? i was debating adding a Varimax http://www.lingenfelter.com/mm5/merc...6#.VYnCWflVhBc
    or the Jabsco http://www.amazon.com/gp/product/B00..._email_1p_0_ti
    These pumps have both been tested for american cars and flow very well.
    Aug 03 2014
    Queens
    I looked at Varimax.. Good reviews on the CTSV forums. I believe AMS uses the same pump.
    Previous
    Feb 13 2004
    S Ã C, CÃ*
    Link to the Install document.
    http://1drv.ms/1fFeTnE
    Senior Member Three Rings kap09's Avatar
    Jun 22 2010
    2017 Grand Cherokee, 2015 Fiat 500e, 2016 eGolf, 1989 Jeep Wagoneer
    PM sent. Had major heat issues on Targa Trophy last weekend. Might need to bite the bullet on this.
    2014 S4 | DSG | Ibis White | Sport Diff | MMI | Carbon Atlas | B&O | Side Assist | SC Badged
    GIAC Stage 2 v2 | GIAC DSG | Roc-Euro Intake | AWE 102mm | Brembo 380mm | Deval Rear | OZ Leggera | Michelin PSS | OE Sport | AluKruez | H&R Sways | 40% Pinnacle Tint | Hoen Endurance | VCDS Mods | Escort 8500 x50
    Past Rides
    2013 S4 6MT//2010 A4 Quattro//2000 BMW 323i//1991 Integra//1990 Jetta//1993 Civic
    @kap9 on Instagram
    Dec 27 2014
    PM Sent!
    Dec 19 2010
    North CA
    No mo heatsoak!
    Edit: Also, I used about 2 gallons of fluid (1 gallon of factory non-diluted coolant plus 1 gallon of distilled water)
    Since I had a lot of coolant in the reservoir, I used the bleed screws on top of the SC to get the coolant to drain out of the reservoir so I could use the vacuum filler tool. 2x tries and system seems to be air free (did the bleeder check on the SC to verify)
    Mesh installed! (Reused from old mesh guard)
    Feb 13 2004
    S Ã C, CÃ*
    The vendor told me that there are only a few spots left at the intro price, PM me for details.
    Dec 19 2010
    North CA
    Also, the paint I used seems to be holding up well... No damage from the heat.
    Aug 03 2014
    Queens
    I installed the plm heat exchanger. Didn't get the pump atm but I ended up doing some quick logging of the iats. Nothing crazy. I'll do some more on my days off. I'm fairly new to vag com and I'm quickly posting what I seen.
    After a good hour drive and idling I ended pulling out the computer.
    Coolant temp - 94c
    Ambient temp - 30c
    Iat - 50c
    First gear pull iat dropped to 48c
    Second gear pull picked up to about 50c
    Third gear pull went up to about 53c
    The recovery time was quick. Dropped down to 50c while idling but coolant did go up to 99c.
    Did one more pull about 30 seconds in and I had the same results as above.
    Coast about 1/8 of a mile and it dropped back down to 48c and coolant went down to 94c.
    Once I have the time I'll do back to back pulls and try my best to heat soak the engine.
    Hope this helps a bit for anybody thinking about pulling the trigger.
    Previous
    Feb 25 2013
    MI
    Aren't you just logging your engine coolant with VCDS or using a temp gun like infinkc? The engine coolant shouldn't really be affected by the upgraded blower coolant loop. Would be nice if there were some sensors in the blower loop, but I believe it's no dice in terms of vcds. But the IAT measurement is certainly important, arguably the most important. If you are only showing 5 deg C of increase after sustained pulls then I would say that is solid performance. APR, AWE, and AMS have some data you could look at for comparison.
    Dec 19 2010
    North CA
    It does affect it a little. But the almost non existence of heat soak is quite nice in day to day driving.
    Aug 03 2014
    Queens
    This was done with with VCDS. As for the engine coolant I'm not sure how much of an effect it would have on the HX but I threw it up anyway.
    I compared it with APR's graph but I will have to do multiple low 3rd gear pulls to try and get an accurate comparison. I'll give it a shot.
    Feb 25 2013
    MI
    I wasn't trying to say the measurements are useless, just make sure that you understand the engine coolant loop is where that sensor is. The system is not divorced (like APR or AWE), so there is an opportunity for the circuits to transfer heat back and forth. But like infinkc said in the OP, the amount will likely be negligible. The main failure mode you are avoiding is if the supercharger loop somehow becomes drained...then you will know because the engine loop/overfill tank will simultaneously drain and you'll get a warning in dash.
    Skywagon actually installed an analog sensor probe in the outlet of his CPS heat exchanger, and hooked it up to his P3 gauge. This is really the best measure to check performance of the CPS system IMO (I'm no expert on this testing however, so maybe there is something better).
    But like I said, the whole point of the system is to keep IAT's in check, so logging that will truly tell the story. Sounds like yours is working well
    Jul 01 2015
    NS Canada
    infinkc, PM sent!
    Senior Member Three Rings bokiboki's Avatar
    Apr 26 2013
    Bronx, NY
    PM sent.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    I'm really not impressed with the price point. AWE is $100 more? AWE all day on that decision.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by rtl5009 View Post
    At the GB price it was much more than $100, but now since AWE dropped their price its a hard comparison.
    The GB is no longer active.
    Jul 28 2009
    Philadelphia PA
    Yea awe's reseviour is sexy. And I'm pretty sure I can make a pump for less than $200 with a b20 electric water pump.
    c8 a6 allroad
    May 04 2015
    san francisco
    I just contacted PLM and they said they are willing to price match and beat AWE's pricing and it seems like AWE's doesn't come with the reservoir tank like PLM for additional fluids. Pm me if you want details.
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Does painting the Heat Exchanger change its efficiency at all?
