Results 1 to 18 of 18
    Apr 28 2015
    Engine wire harness diagram
    Anybody have a diagram that shows all the plug locations for the engine harness for a 2.7t?
    Thought I could remove it and when I put it back on the engine, all the plugs would just be back in place. Turns out there is a few similar looking plugs. I think I got it back on correctly but would like to double check before putting it back in the car.
    Thanks
    Feb 23 2007
    mk2 vrT
    east coast destruction
    Post pics of specifics, the harnesses generally only install one way and are color coded and keyed where there is a possibility of swapping connectors
    Apr 28 2015
    Ok a few connections are killing me.
    Where is the plug that goes into the driver side axle?
    Where is the plug that goes into the passenger side of the tranny
    And where do all these plug in to? These plugs are at the end of the harness that has O2 sensors
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    Last one is ICMs?
    Apr 28 2015
    Nope I have those hooked up already
    Apr 28 2015
    Just realized it has this clip. If I can figure out where it clips, maybe I can figure out where they all plug in
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    All of those are in the rear and to the left correct? Maf, starter, 02s, and some blue clip. Everything is color coded. The ones for the Trans will be between your left and right side 02 connects. In the center rear of motor. The split left and right.
    May 22 2013
    Las Vegas, NV
    In fact the last picture shows the wire to driver side axle. Long like a serial port with a push in metal clip
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    He's right (I think) they are all the clips that mount on the left on the false firewall.
    2002 Pearl/onyx S4 Avant
    Established Member Two Rings Mr.Z's Avatar
    Mar 19 2012
    audi junk stuff
    Richland WA
    firs pic is speed sensor next one is revers light. i can provide pics if u want
    Mar 19 2012
    audi junk stuff
    Richland WA
    the clip hold the wires to the tranny for o2 sensors ect
    Apr 28 2015
    Awesome, so speed sensor and reverse light. Can you tell me where on the harness the plug is? I feel Redicilous I can't figure it out.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    You're thinking to far ahead! Drop the motor
    back in and all the plug locations on the harness
    become self evident as you go along.
    Apr 28 2015
    Haha that's exactly what I'm doing. About to finish hooking up the half shafts then exhaust, then work on these plugs some more
    Apr 28 2015
    Ok so all those random plugs go into the maf, O2s and the 4 plugs on the airbox.
    I never did find the plugs for the speed sensor and reverse light. I didn't get a chance to see if she'll start because I think the oil pan is cracked due to it all coming right out the bottom when I pour it in.
    May 22 2013
    Las Vegas, NV
    You can't see where it's coming out from?
    Apr 28 2015
    I can't find the plugs on the harness for the speed sensor or reverse light
    Apr 28 2015
    Found this thread with a layout of the engine harness:
    http://www.audizine.com/forum/showth...for-my-project
    Has this:
    and this
    This should help.
