Results 1 to 28 of 28
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Interior Touch Up Paint Evaluation
    My objective was to find the best match as I could to touch up some of the wear and tear on my black interior. The ultimate repair would be an exact match spray-on rubberized coating. For the evaluation I considered these three spray on coatings:
    I have used the Krylon Camo and Dupli-Color Vinyl & Fabric in the past and had high hopes for the Tamiya which is a spray-on rubberized coating. For the first comparison I sprayed the vent on the left with Krylon Camo and the vent on the right with Tamiya. The shifter plate cover is the OEM coating.
    Both seem to be a pretty good match. So next I picked a spot on the back of the center console to compare the Dupli-Color V&F with the Tamiya. Here’s the test area:
    I wanted to be able to spray the damaged areas in place without removing them so the coating would have to be able to blend with the surrounding areas.
    Here are the results from the Dupli-Color V&F. As you can see it is “blacker” than the surrounding area. It’s very apparent where I over sprayed the masking tape.
    Next I sprayed the other side with the Tamiya rubberized coating. It was a better match than the V&T but it was a bit lighter and grayer than the console.
    I really wasn’t happy with either result so I then re-sprayed both sides with the Krylon Camo. As you can see I also repaired the over-sprayed area from the V&F.
    This was by far the best result of the three. I then proceeded to use the Krylon Camo to make repairs on the front portion of the center console. I apologize for not taking before pics. The damage was similar to what you saw on the rear portion of the console. Worn shiny dark black spots. I sprayed the upper curved portion and masked off the lower panel:
    In this pic I sprayed the section below the shift plate cover. It was very scarred up similar to the rear console.
    All in all I’m very pleased with the results that I obtained without having to pull out and strip down the console. The key to spraying the Krylon Camo is to use several very light coats. If you spray it on too heavy it will dry darker and not blend in with the OEM coating.
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    nj
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    it seems like that Krylon is best for the interior trim like the console and pieces like that, and that Tamiya might be best for things like the HVAC unit and other buttons and things like that, would you agree?
    Looks very good, thanks for the info.
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Dec 28 2006
    Western Maryland
    I agree that Tamiya may work better on things like the HVAC unit and other buttons on the panel so I decided to give it a try. As you can see the radio knob was worn and there was peeling around the knob.
    Here’s a close-up of the peeling.
    I had to brush the coating on the peeled section. I lightly sanded with some 2,000 grit before brushing on the Tamiya. It isn’t perfect but it does look acceptable when you aren’t looking at it in extreme close-up.
    Sprayed knob before and after.
    And the finished product. Again, it looks better in person than in the extreme close-up. All in all I think it’s an acceptable repair.
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    looks good! my console is quite worn as well and that Krylon camo is definitely an option.
    Jan 09 2012
    MA
    Looks great for the black trim.
    Anyone have any suggestions for matching platinum grey?
    Apr 07 2011
    I'm interested as well. Just about the same places on mine are showing wear.
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Looks like I have to pick up a can of the Krylon as well and spruce up my peeling interior. Nice job OG!
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Feb 17 2004
    Liberty Hill, TX
    I'm kind of shocked you actually sprayed it inside the car, given that it takes all of 10-15 mins to remove the center console, at which point you could simply respray the entire thing, as well as not have to worry about overspray inside the car.
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    which has the best feel after dry? do they feel like enamel?, or do they feel like regular spray paint with the super dry almost chalky touch finish?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Matt Devo View Post
    I only had a few spots that needed repair so I chose to address the spots rather than the whole console. Most of the masking was simply index cards and a little painters tape. I spent way more time taking pics than the actual repair. Had the damage been greater I would have refinished the entire console but I was really looking for something that I could use to address the small rub spots as they occur rather than a complete refinish every time a blemish popped up.
    Quote Originally Posted by BARRY View Post
    The Tamiya had an OEM feel. The V&F had an enamel feel and the Krylon Camo was a little dry. After it cured I swiped the Krylon with some low gloss vinyl protectant and it took care of any "dryness". This is the same process I used to refinish my Podi back in '09 and it still looks like it did when I first installed it. Clicky click® I don't think the Auto Sport is still available but I'm sure there are other low gloss vinyl sprays available.
    [IMG][/IMG]
    Nov 02 2007
    SF Bay Area, CA
    great thanks for doing this!
    Jun 27 2011
    This is great OG. I'm actually going to pick some up and spray my podi gauge now when I take it out to repair the mounting hole. Awesome.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Guys, where to buy this "Tamiya rubberized coating"?
    I guess it must be a U.S product as I've never seen it anywhere in Canada and in google only plastidip is returned...Any links to Amazon or ebay link for purchase would be appreciated, thanks in advance OP for guide and pics
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by BenMTL View Post
    Clicky click®
    Dec 19 2012
    Europe
    Thanks old guy but I think that is the wrong link?
    Is this the right one? TS80?
    https://www.amazon.com/TAMIYA-TS-80-...Z3EV30THJR63AZ
    Dec 28 2006
    Western Maryland
    Dec 19 2012
    Europe
    Oh sorry my mistake...just the picture threw me off, but that is definitely the right link!!
    Thanks
    Active Member Two Rings HalfAudio's Avatar
    Sep 24 2011
    A4 1.8 1996
    UK/Staffordshire
    I has been a while would you be so kind and show us how well it was holding on? i was thinking to spray gently a bit of plastic adhesion promoter before the actual paint.
    Moving forward
    Audi 90 2.3E (1989)
    Audi A4 1.8 (1995)
    Audi A4 1.8 (1996)
    Audi a4 b6 avant 1.9Tdi (2003/2004)
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by HalfAudio View Post
    I think it has held up quite well.
    Recently I used the Krylon to repaint the drivers door master switch panel. It was all scratched up. Turned out really nice! Switches were replaced at the same time.
    Established Member Two Rings CD155mx's Avatar
    Dec 10 2008
    Very cool. Thanks for sharing.
    WTB: Manual Transmission B6/B7 Avant. USP, S-Line Titanium, or S4. Prefer White, Nagaro, Imola
    Jazz Blue 20th AE GTI No. 2062 Documentation Thread
    2013 F-150 FX4 CC EB 6.5' Bed Maintenance Thread
    Sep 24 2011
    A4 1.8 1996
    UK/Staffordshire
    WOOW that is actually pretty impressive I will give this a go once i will get a decent weather outside.. I will share the before and after pic once it ill be done
    Are those the chinese switches or genuine one? I failed to change mine years a go, because i bought the chinese ones and thought i will be able to swap the plastick bits, only i was so wrong...
    Moving forward
    Audi 90 2.3E (1989)
    Audi A4 1.8 (1995)
    Audi A4 1.8 (1996)
    Senior Member Two Rings Natejo91's Avatar
    Apr 05 2017
    Porsche Cayman S, Toyota 4Runner, Suzuki SV650
    Thanks for posting this OG! How many coats are you applying on these touch ups? Just one coat with some light sanding before applying? Also which one was the best for the shifter bezel and ash tray up front?
    2003 B6 Quattro MT | Polar White w/ Ebony interior | B7 seat swap | B7 Center Console | JHM + Black Forest Shifter | B8.5 MFSW | RNS-E | Brembo 18Z calipers front | S4 rear calipers | S4 front sway bar | RS4 rear sway bar | Bilstein B8 kit w/ H&R sport springs | Bosch 550cc injectors | Tubular high flow exhaust manifold | K04 | 3" MAF | 034 Motorsport 3" test pipe | B7 Dual Sidemount Intercoolers and Motoza K04/Hybrid tune
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Natejo91 View Post
    I would recommend the Krylon. It seems to be a bit more durable than the Tamiya. The Tamiya has a more tactile soft touch feel but chips easier. Use Goo Gone or something similar to remove the old soft touch material. Let it soak for a bit and then you can rub it off. Clean it thoroughly. I didn't sand it but I did use a Dupli-Color Prep-Wipe before spraying. I used multiple light coats allowing several minutes between coats. I found that if you use a heavy coat the final color tends to be darker than the OEM color.
    HalfAudio: I picked up the door switches dirt cheap from Amazon. They work fine and actually corrected the one touch feature that had quit working with the OEM switches.
    Apr 05 2017
    Good to know! Thanks for the recommendation! Does the chrome lip on the shifter bezel pop out or did you mask it off for the respray?
    Dec 28 2006
    Western Maryland
    It doesn't pop off but it is removable. There are multiple tabs that stick through and the tips are heat sealed. if you have a Dremel is is pretty easy to remove the melted heat seal and pop the trim out. There will be plenty of the tab remaining to secure it back with a few drops of superglue or hot melt.
    Sep 24 2011
    A4 1.8 1996
    UK/Staffordshire
    They are all the same at first glance but the internals are totally different i didn't fit mine because it had an ugly sounding click.
    One last thing,is there a special technique to remove the radio knobs or just pliers sounds harsh...
    Moving forward
    Audi 90 2.3E (1989)
    Audi A4 1.8 (1995)
    Audi A4 1.8 (1996)
    Dec 28 2006
    Western Maryland
    No pliers required. Just pull off with your fingers.
