For anyone who has replaced their OEM brake pads with ceramic ones (specifically Wearever Gold or Akebono), did you install the ceramic pads in the front only and then swap the rear ceramics in at a later date, and if so did you notice an additional decrease in initial bite when pressing the brake pedal after swapping the rear pads? Or is the braking force biased enough toward the front that changing the rear pads would have no appreciable change in overall braking feel?
EDIT: My current situation is that I have installed Wearever Gold pads in the front but left the rear OEM pads in place. I'm happy with the decreased dusting from the front pads on my matte finish wheels so I am considering also swapping the rears, but I'm curious if I will notice any additional reduction in initial bite when doing so.
