Results 1 to 12 of 12
    Established Member Two Rings photocycler's Avatar
    Jun 07 2015
    United States
    Plasti Dip Grille and Logos - questions
    About to have my first go with plasti dip on the grille and had some questions. If I keep the bumper on is it difficult to mask behind the grille?
    If I go the route of removing the bumper should I expect it to go back on perfect without anything breaking?
    For the badges on the rear, any idea on where to buy a matte black Audi ring badge? I assume that would be easier than masking and painting the rear badge. Thx
    Sep 17 2014
    Austin, TX
    audibadges. com for the matte black rear badge
    Jun 07 2015
    United States
    Quote Originally Posted by d4fotografix View Post
    Would you recommend also getting the front badge in matte black instead of plastic dipping?
    Sep 17 2014
    Austin, TX
    I dipped it with the grill so it would match exactly. On the rear, I bought one slightly larger than stock. I liked it better on my A3.
    May 25 2015
    New Jersey
    I dipped my S3 front grill the other day. Left it on the car and used blue painters tape on areas I didnt want to get dip. In addition, if leaving it on the car make sure you pop the hood and cover the radiator with plastic so you dont get overspray in there. It was really easy to do and areas where there was overspray on the car it rubbed right off. Having never used the stuff before I was very surprised. As for the rear- my skills were not up to par on the emblems so I peeled it off with no issues and will try again this weekend. I rushed it and didnt give enough coats prior to trimming it.
    2015 Audi S3 Premium Plus
    Convenience Package: MMI: Sport
    Jun 07 2015
    United States
    Quote Originally Posted by cde1218 View Post
    Was it hard to mask off behind the grille, its so tight in there wasn't sure how easy it would be to get to
    Jun 07 2015
    United States
    Ok, plasti dipped the front grille and rear emblems and it came out good.
    I purchased a gloss black ring emblem for the grille and also a gloss black s line emblem for the grille, does anyone know hwo to remove the s line emblem without removing the grille?
    Active Member Two Rings TheAngryGiraffe's Avatar
    Jul 13 2014
    Denver, Colorado
    It's held on with two metal clips. One on each side. You can push them off with your fingers, just make sure you don't drop them or they will be stuck behind the bumper.
    Jun 07 2015
    United States
    Anyone know if it would be possible to peel the plasti dip off the rings logo easily without damaging the bumper coat?
    Jan 24 2010
    Indiana
    if its done right it will not damage anything
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    If you really want it black .. paint it with the right stuff . Every one dips it but no one paints it.its the little things that make it better .
    Veteran Member Four Rings Das Ponto's Avatar
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Quote Originally Posted by CLEANA3 View Post
    agreed!!!!!!!
    Ponto
    2020 Glacier White A4 Allroad | 034 Dynamic Springs | 034 Intake | Unitronic Stage 1+ | Rotiform SGN
    2022 Daytona Grey Q7 | Quattro Magazine's Project Q7 Offroad | H&R Lift Springs | Black Rhino Volls | BFG KO2's | Rokblock Mud Flaps
    Instagram: Dasponto | Flickr
