I searched everywhere about the speed/noise dependant volume and says you can't program it out.
I guess the common fix is to unplug the mic, which I didn't want to do because of my Bluetooth, or cut a wire at the AMP. I didn't really want to do that either.
The drone inside the car would make the radio go crazy with your throttle inputs and that was annoying as all hell. So I went through Vag Com because I thought it had to be in there even though the masses said it wasn't.
Long story short if you want to turn off the microphone and/or speed adjusted volume it's pretty simple.
In VagCom go:
56 - Radio
Adaptations
Channel 8
The old value should be 255 if you have Bose.
Enter 000
Test
Save
Done
Has worked perfectly thus far and can't find anything else that has changed.
