Page 1 of 7 123 ... LastLast
Results 1 to 40 of 245
    Sep 17 2005
    Fremont, California
    They're Here! 034Motorsport B8 Audi A4 Rear Differential Mount Inserts & X-Brace!
    Introductory Special: ENDED
    We're pleased to announce an exclusive Introductory Special on a line of all-new B8/B8.5 Audi A4 Drivetrain & Chassis Upgrades by 034Motorsport! These performance parts are in-stock and ready to ship.
    034Motorsport Drivetrain Mount Insert Package, B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5 Billet Aluminum
    Retail: $255.00 + Shipping
    Introductory Special: $225.00 + Shipping
    (Individual inserts are available separately below.)
    Introductory special pricing is available through June 20th. Thank you for all of the interest, and we hope you enjoy this new line of performance upgrades for your Audi!
    034Motorsport is proud to offer our Billet Aluminum Drivetrain Mount Insert Package for the B8 Audi A4/S4/RS4, A5/S5/RS5, and Q5/SQ5! The factory Audi transmission and rear differential mounts have large voids in the rubber damping medium, which results in excessive drivetrain movement under load. This movement results in slop than can be observed when accelerating, decelerating, shifting, and launching.
    These billet aluminum inserts are designed to fill the large voids in the factory transmission and rear differential mounts, and limit drivetrain movement without sacrificing ride quality or introducing any additional noise, vibration, or harshness into the cabin. By filling the voids in the factory mounts, this package eliminates the associated slop to ensure that you experience crisper shifts, harder launches, and a smoother driving experience.
    This mount insert package was thoroughly tested by 034Motorsport, JH Motorsports, and independent Audi enthusiasts before release. Installation is very simple, can be performed in minutes, and is completely reversible.
    Features:
    • T6-6061 Billet Aluminum Construction
    • CNC-Machined In-House
    • Clear Anodized Finish for Durability
    • Engineered to Fill Voids In Factory Transmission/Differential Mounts
    • Drastically Reduces Transmission & Differential Movement During Shifting & Deceleration
    • Improves Shifting Feel, Resulting in Crisper Shifts
    • Allows for Harder Launches & Better Response from Rear Differential
    • Will Not Cause Additional NVH Transfer Inside Cabin
    • Easy, Straightforward Installation Takes Minutes!
    What's Included:
    Installation Instructions:
    • Transmission Mount Insert: Web - PDF
    • Rear Differential Mount Insert (Front): Web - PDF
    • Rear Differential Carrier Mount Insert (Rear): Web - PDF
    Fitment:
    • 2009 - Present Audi A4 (B8/B8.5) - Quattro Models Only
    • 2010 - Present Audi S4 (B8/B8.5)
    • 2013 - Present Audi RS4 (B8/B8.5)
    • 2008 - Present Audi A5 (B8/B8.5) - Quattro Models Only
    • 2008 - Present Audi S5 (B8/B8.5)
    • 2013 - Present Audi RS5 (B8/B8.5)
    • 2008 - Present Audi Q5/SQ5 (B8/B8.5)
    • 2010 - Present Audi A8 (D4) - Quattro Models Only
    • 2012 - Present Audi S8 (D4)
    The new Rear Differential Mount Inserts are also available separately!
    034Motorsport Rear Differential Carrier Mount Insert Kit, B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5
    Retail: $95.00 + Shipping
    Introductory Special: $85.00 + Shipping
    034Motorsport Rear Differential (Front) Mount Upgrade Kit, B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5
    Retail: $85.00 + Shipping
    Introductory Special: $78.00 + Shipping
    034Motorsport X-Brace Billet Aluminum Chassis Reinforcement, B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5
    Retail: $495.00 + Shipping
    Introductory Special: $445.00 + Shipping
    034Motorsport is proud to offer our Billet Aluminum X-Brace Chassis Reinforcement Upgrade for the B8 & B8.5 Audi A4/S4/RS4, A5/S5/RS5, and Q5/SQ5! The factory Audi front subframe brace is manufactured from multiple pieces of stamped steel, and allows for performance-hindering chassis flex under load. This torsional flex can result in improper suspension geometry and alignment when cornering, and leads to vague steering feel and lack of steering precision.
    The 034Motorsport X-Brace is a billet aluminum chassis reinforcement to replace the factory front subframe brace to increase torsional rigidity, resulting in improved steering feel and handling performance. Machined in-house from T6-6061 billet aluminum, the 034Motorsport X-Brace is engineered to outperform the stock welded, stamped steel part and ensure that suspension geometry is not compromised by chassis flex under hard cornering.
    This chassis brace upgrade was thoroughly tested by 034Motorsport and independent Audi enthusiasts before release. Installation is very simple, can be performed in minutes, and is completely reversible.
    Features:
    • Engineered to Replace Factory Front Subframe Brace
    • Drastically Reduces Chassis Flex When Cornering
    • Enhances Handling Dynamics and Performance
    • Improves Steering Feel, Consistency, and Precision
    • Modular Design Fits Both B8 (Pre-Facelift) & B8.5 (Facelift) Models
    • Easy, Straightforward Installation!
    What's Included:
    • 034Motorsport Billet Aluminum X-Brace Chassis Reinforcement (Fits B8/B8.5 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5)
    • Modular X-Brace Inserts (Set of 2)
    • M10 X-Brace Assembly Screws (Set of 4)
    • M5 Undercarriage Tray Mounting Screws (Set of 4)
    • 15mm Undercarriage Tray Mounting Washers (Set of 4)
    Fitment:
    • 2009 - Present Audi A4 (B8/B8.5) - All LHD Models
    • 2010 - Present Audi S4 (B8/B8.5) - All LHD Models
    • 2013 - Present Audi RS4 (B8/B8.5) - All LHD Models
    • 2008 - Present Audi A5 (B8/B8.5) - All LHD Models Except Cabriolet
    • 2008 - Present Audi S5 (B8/B8.5) - All LHD Models Except Cabriolet
    • 2013 - Present Audi RS5 (B8/B8.5)- All LHD Models Except Cabriolet
    • 2008 - Present Audi Q5/SQ5 (B8/B8.5) - All LHD Models
    Replaces:
    • 8T1 399 345J / 8T1399345J
    • 8K1 399 345E / 8K1399345E
    Please Note:
    Please don't hesitate to contact us via PM or email if you have any questions.
    Click Here to Order Full Drivetrain Insert Package!
    Click Here to Order Rear Differential Carrier Mount Insert Pair
    Click Here to Order Rear Differential (Front) Mount Insert Pair - Please Note: This product will replace any existing polyurethane insert upgrade, if you already have one installed.
    Click Here to Order Transmission Mount Insert
    Click Here to Order X-Brace
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    No email no order...
    Who am I kidding order placed, should have waited for them all to be released before I went apikol though...
    Established Member Two Rings djspecv's Avatar
    Oct 08 2014
    BMW M5 Competition
    Just ordered the rear diff carrier mount. Already had the apikol rear diff mount insert, EC alu kreuz and 034 tranny mount.
    Anybody that experiences apikol vs 034 rear diff mount insert pls comment. Curious to know if there's a difference. Same thing with ec alu kreuz vs 034 x brace.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Established Member Two Rings b8tamaster's Avatar
    Jun 18 2014
    Just ordered the carrier inserts. Very excited!
    Veteran Member Four Rings pwdrskr's Avatar
    Aug 21 2010
    Carlsbad, CA
    I have an apikol and the 034 Trans Mount already, so all I'd "need" is the Rear Differential Mount Inserts right?
    '19RS5 Coupe: Prestige, Daytona Grey, Blk Interior, Carbon Pkg, Driver Pkgs, APR+/TCU/Intake, CETE AVC, ABT Coils, Vossen EVO-1R 20x10et20
    '22RS6: Glacier White, Blk/Gray Interior, Blk Optics, Exec, Driver Pkgs, Sport Exhaust, APR+, Akrapovič Exhaust, CETE AVC/ASC, Vossen GNS-1 22x10.5 et7, Stealth wrapped Piano Black Interior
    Senior Member Two Rings archangel.308's Avatar
    May 30 2011
    2022 Audi SQ8 /2018 Audi SQ5
    Chandler, AZ
    I placed my Order.... now the wait begins ... ughhhh
    Turbo: Exhaust gasses go in, witchcraft happens and you go faster. - Jeremy Clarkson
    MODS:
    • SQ5: (B9) IE Intercooler and Carbon Fiber Intake Kit w/ Inlet pipe., 034 Transmission and Rear Subframe Mount Insert, 034 Billet Oil Filter Housing,
    • SQ8: (4M) 034 Transmission Mount Insert, and Billet Oil Filter Housing
    • R8 V10 (MK1) Stock
    Sep 17 2005
    Fremont, California
    Thank you for all of the orders!
    Quote Originally Posted by pwdrskr View Post
    That's correct! Glad you asked; it's hard to fit so much information clearly in one post.
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    Rear mounts orderd
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Dec 19 2006
    996TT
    San Antonio, TX
    So what is the difference b/w your front diff mount and the Apikol bushings? Will yours work with the Apikol, or does it work in it's place?
    Sep 10 2012
    Bham AL
    Quote Originally Posted by poweredbyaudi7 View Post
    It takes the place of it, its metal instead of poly.
    Senior Member Two Rings eirebob's Avatar
    Apr 13 2010
    santa rosa ca
    Just ordered the carrier inserts. I'll post a review after install.
    2009 A4 Quattro, Manual, Prem Plus, Sport Package
    Mods: APR Stage II, Stratmosphere short shifter, Alu Kreuz, Tips, Tint, 034 Turbo hose, Cocomats. EC Intercooler pipe, hose kit. RS 5 pedals. Apikol rear diff kit. Vag.com mods. Stoptech slotted rotors, Akebono pads. Interior LEDs, BFI heavyweight knob, CF trim. BC BR coils. P3 Guage. ECS SS brake lines, 10/15 spacers. CR 15 brace. USP HFC.
    Sep 17 2005
    Fremont, California
    Rear mounts orderd
    Thank you for the order!
    For the front mount for the rear differential, you have to decide between the 034 and the Apikiol option, as you cannot run both. Our inserts are made from billet aluminum that isn't prone to degrading over time. They are also designed to more closely fill the voids in the factory mounts.
    Quote Originally Posted by eirebob View Post
    Looking forward to your review!
    Sep 17 2005
    Fremont, California
    So many orders! (Thank you!)
    We still have a few of the Rear Differential Carrier Mount Inserts and Rear Differential (Front) Mount Upgrades left. We also still have a handful of the first run of X-Brace Chassis Reinforcement Upgrades ready to ship. We've already started machining more of them in case we run out, and stock should be replenished before the Introductory Special pricing ends.
    Feb 13 2004
    Silicon Valley, CA
    Been running the diff mounts on my Avant for a few weeks now. no complaints at all, no vibrations. Great!
    Kevin - Moderator, Audizine
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Ordered the inserts! Can't wait to follow the step-by-step instructions!
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Stubek View Post
    Thanks Kevin! Glad you like.
    Quote Originally Posted by andrewmoore13 View Post
    Sep 17 2005
    Fremont, California
    I know that was a lot of information to put in one post, so I'll be going through and posting details about the individual components as the Introductory Special continues.
    034Motorsport B8 Audi A4 Quattro Rear Differential Carrier Mount Insert Kit, Billet Aluminum
    034Motorsport is pleased to present another first for the B8 Audi A4, with our Billet Aluminum Rear Differential Carrier Mount Insert Upgrade Kit! The factory Audi rear differential carrier bushings have voids in the rubber damping medium, which results in excessive rear differential movement (twisting) under load. This movement allows for unwanted drivetrain slop (and sometimes clunks) that can be observed when accelerating, decelerating, and shifting.
    These billet aluminum inserts are designed to fill the voids in the factory B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5 & C7 Audi A6/S6/RS6, A7/S7/RS7 rear differential carrier mounts, and limit rear differential movement without sacrificing ride quality or introducing any additional noise, vibration, or harshness into the cabin. By filling the voids in the factory mounts, these inserts eliminate the associated slop and ensures that you're experiencing smoother shifting and throttle transitions, and an improved driving experience.
    Features:
    • CNC-Machined Billet Aluminum Construction with Clear Anodized Finish
    • Application-Specific Design for Optimal Fitment and Performance
    • Engineered to Fill Voids In Factory Rear Differential Mounts
    • Drastically Reduces Rear Differential Movement During Shifting, Acceleration, and Deceleration
    What's Included:
    • 034Motorsport Billet Aluminum Rear Differential Carrier Mount Insert Pair
    Fitment:
    • 2009 - Present Audi A4 (B8) - Quattro Models Only
    • 2010 - Present Audi S4 (B8)
    • 2013 - Present Audi RS4 (B8)
    • 2008 - Present Audi A5 (B8) - Quattro Models Only
    • 2008 - Present Audi S5 (B8)
    • 2013 - Present Audi RS5 (B8)
    • 2008 - Present Audi Q5/SQ5 (B8)
    • 2012 - Present Audi A6 (C7) - Quattro Models Only
    • 2012 - Present Audi S6 (C7)
    • 2012 - Present Audi RS6 (C7)
    • 2012 - Present Audi A7 (C7) - Quattro Models Only
    • 2012 - Present Audi S7 (C7)
    • 2012 - Present Audi RS7 (C7)
    Installs Into:
    • 8K0 599 257N / 8K0599257N
    Sep 17 2005
    Fremont, California
    SOLD OUT! - We have sold out of the first run of the 034-505-2016 Rear Diff Carrier Inserts! The good news is that a new production run is already underway, and will be at anodizing shortly. This may delay some orders a few extra business days, but we will continue to offer the Introductory Special pricing through the 20th. Thank you for all of the orders, and your patience as our Manufacturing Department catches up!
    034Motorsport Rear Differential Carrier Mount Insert Kit, B8/B8.5 Audi A4 Quattro & Allroad
    Here is the latest run of Rear Diff Carrier Bushing Inserts being machined from billet aluminum on our Haas VF2 Vertical Mill.
    Sep 17 2005
    Fremont, California
    Happy Friday! Here are some more details on the second piece to the rear differential mounting puzzle.
    034Motorsport B8/B8.5 Audi A4 Quattro Rear Differential (Front) Mount Upgrade Kit
    034Motorsport is pleased to present our new Billet Aluminum Rear Differential Mount Insert Upgrade for the B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5 & C7 Audi A6/S6/RS6, A7/S7/RS7! The factory Audi rear differential mount has voids in the rubber damping medium, which results in excessive rear differential movement under load. This movement allows for unwanted drivetrain slop (and sometimes clunks) that can be observed when accelerating, decelerating, and shifting.
    These billet aluminum inserts are designed to fill the voids in both sides of the front-most factory B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5 & C7 Audi A6/S6/RS6, A7/S7/RS7 rear differential mount, and limit rear differential movement without sacrificing ride quality or introducing any additional noise, vibration, or harshness into the cabin. By filling the voids in the factory mounts, these inserts eliminate the associated slop and ensures that you're experiencing smoother shifting and throttle transitions, and an improved driving experience.
    Installation is very simple, can be performed in minutes, and is completely reversible. These billet aluminum inserts are precision-machined to fill voids on both sides of the factory rear differential mount, and will not pack and wear out over time.
    Features:
    • Engineered to Fill Voids In Both Sides of Factory Rear Differential Mount
    What's Included:
    • 034Motorsport Billet Aluminum Rear Differential Mount Upgrade (Top Insert | 505-2017)
    • 034Motorsport Billet Aluminum Rear Differential Mount Upgrade (Bottom Insert | 505-2018)
    Fitment:
    Installs Into:
    • 8K0 599 381H / 8K0599381H
    • 8K0 599 381J / 8K0599381J
    Sep 10 2012
    Bham AL
    I want the X-brace soo bad...
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    Quote Originally Posted by Dub_prime View Post
    Yea I'm curious to get some feedback on this. I think I'd rather get a 034 part than a Eurocode one. I feel like there's just more motorsports pedigree behind it.
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    They're Here! 034Motorsport B8 Audi A4 Rear Differential Mount Inserts & X-Br...
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Oct 26 2012
    St. Louis, MO
    Shite. I see a little rust under there now that i need to investigate.
    The mount inserts though..
    First: My bolts were hella tight and I needed a breaker bar to get them loose. (may have also been the injured rib weakening me)
    Second: Use the lube boys. The inserts don't glide on in like the 034 gif shows. They draw in as you tighten the bolt (would be funnier if it was a nut).
    Third: WEEEEEEEEEE. I like it
    Already have the trans mount and the spulen diff mount and those made shifting crisper and the car feel more sporty. Maybe the oxygen level in the air tonight is extremely high, but these mounts made the car feel like it has 20 more HP. Throttle response is soooo much better and cornering is a joy as the rear really hooks up. A short shifter would make a nice addition now.
    Apr 13 2010
    santa rosa ca
    I got my inserts in as well today ... took me about an hour. I agree with Blbroo ( Bob ); they don't just slide in. The bolt draws them in.
    My bolts came loose easily. Removing them was a little more time consuming, because my socket wrench would quickly bump against the spare wheel indent in the trunk. Install was similarly slowed. No big deal, just a little more time.
    I also have a manual, and would agree with 034's summary ... smoother shifting, better throttle transition. So the engine feels like it's getting to its power that bit quicker. I'm not as impressed as the other Bob, but I do like it. And no NVH issue to speak of in my 15 or so miles of driving.
    Recommended; for its positive impact, modest price, and ease of install.
    Senior Member Two Rings Lockon_B7's Avatar
    Oct 17 2014
    New Jersey
    Mine were delivered Friday. However, I forgot my tools at work, so they will go in later today!
    2016 A4 auto P+ Daily driver
    2016 S3 Sepang Blue Sold
    2009 A4 2.0T, 6MT, P+, Sport Package, Meteor Grey. Sold
    2008 A4 2.0T 6MT RIP
    Aug 21 2010
    Carlsbad, CA
    Got mine today, install this weekend!
    Oct 26 2012
    St. Louis, MO
    Haha, Bob. My name is not Robert Paulson. My name is not Robert Paulson.
    I am Jack's questionable sense of humor.
    Will go out for a longer drive this morning to verify my initial impressions.
    Sep 10 2012
    Bham AL
    The best part of waking up, is car parts on your porch!
    Oct 26 2012
    St. Louis, MO
    Took the car out again for a hard run. Rear feels great and hooks up well. The front end now feels loose and sloppy. Not sure if all the tightness in the back transferred slop movement frontwards or if the front was always that soft and feels worse in comparison.
    Perhaps these parts are some scheme by 034 to wear out our engine mounts... ;-)
    Established Member Two Rings Allroad!'s Avatar
    Mar 21 2014
    Probably always had that slop? My allroad has a lot of slop & clunking going on especially at lower speeds when a/t shifts gears. The Transmission mount helped with smoother shifts at higher speeds.
    BMC air filter | Eurocode TRUFit | StopTech rotors | Akebono pads | 034 transmission mount insert | StaSIS rsb | LED interior | de-badged | Alpine Type-R's | S4 pedal set
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by Allroad! View Post
    Yeah. I think you are right. The rear is soo freaking tight now that I was able to kick it out taking a sharp turn from a stoplight.
    Need to figure out how to tighten up the front. I think sway bars.
    Apr 13 2010
    santa rosa ca
    Quote Originally Posted by blbroo View Post
    My God ... NO!! I've named you a Bob when you are not. I can't imagine a much worse fate.
    And who is this creature Jack? Some terrible alter ego?
    Oct 26 2012
    St. Louis, MO
    Really man?....
    It's ok Cornelius, you can cry....
    I am totally wrecking 034's thread now.
    Sep 09 2010
    Destin, FL
    Am I late? I see people are crying again.
    Oct 26 2012
    St. Louis, MO
    I was just saying that I have a questionable sense of humor and dropping some MANdatory culture
    Sep 10 2012
    Bham AL
    Well seized rotors and bearing carriers have slowed me down. The motor mounts are finally on after 6 months in the garage only to find out that the factory ones were old and didn't look bad at all... Soaking everything down and installing the carriers in a few.
    Sep 09 2010
    Destin, FL
    Damn, well at least you have new motor mounts and don't have to worry. I think I just might order their motor mounts after I'm done with this S-Line body conversation.
    Aug 21 2010
    Carlsbad, CA
    Installed but not yet driven on. Or is it driven with? No matter. Took about 30 minutes. Hardest part was the right quarters limiting the range I could move the ratchet through.
    Like others, it took tightening the bolt to fully seat the insert.
    Sep 17 2005
    Fremont, California
    Thank you for the review! So glad you're enjoying the upgrade.
    Also glad to hear you like them! The inserts definitely benefit from some lube, and you can use the bolts to draw them into the mount if necessary.
    Quote Originally Posted by The Infiltrator View Post
    I don't even know what's going on in this thread anymore.
    Congrats on the install! Drive it yet?
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Ordered mine this weekend!
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
