Results 1 to 40 of 73
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Oil Cooler/Oil Filter Housing Gaskets
    DISCLAIMER: I am in no way responsible for any damage that you do to your car in the process. This is my first DIY too; hope it helps!
    For starters, here's a video (two parts) that I followed just to have a reference. Sorry in advance for the potato phone pictures, and the filthy car, but I hope they do the job. Here are some things you'll need:
    • Oil cooler gasket
    • Oil filter housing gasket
    • Full torx set
    • Triple-square set (smaller, to fit a 1/4" driver)
    • 13mm and 10mm sockets
    • A few different length flat-head screwdrivers
    • A philips screwdriver
    • A ratchet (best to have a 1/4" and 3/8") plus extensions and universal joints
    • A 19mm wrench/socket
    • Oil and filter for an oil change
    • Coolant
    • A bucket for fluids, and cat litter
    • Beer!
    I ended up needing an angle grinder to remove a stubborn triple-square bolt, but that's just my luck anyway. Ready?
    1. You did disconnect that battery, right?
    2. Jack the car up and drain the oil. Now would be a good time to change it, so try to wait till you need an oil change for this job.
    3. Once the oil is drained, go for the coolant next. It's a knob next to the small nozzle in the pic, which is near the driver's side IC pipe. Turn it left to open the flow; you may need a set of pliers to get in there to turn it.
    4. Pull coolant bottle away, towards the front of the car. It's just one philips screw.
    5. Undo the hose clamps for the intake manifold pipe, and remove the piece.
    6. I undid the throttle body at this point, as well. You can leave it on, but I found it easier to work with it off. You'll also want to remove as many connectors in the area as possible. I pulled at least 5 of them; they should be easy to spot. It's also worth undoing the plastic tie-straps that hold the bundle together. You can either cut them, or pull them apart.
    7. I didn't grab a picture of this, but you'll want to pull the cable off the alternator now. It's a 13mm nut that may be under a cover (mine wasn't covered). Unscrew that to free up more slack in the bundle.
    8. Now it's time for the two triple-square bolts. They're both on the top side of the oil cooler. The second pic has the bolt already removed.
    9. On top of the oil cooler, there are two 10mm nuts that hold a bracket for two connectors. Get those off, then pull the bracket off.
    10. There are two torx screws (the second one is removed) that hold coolant lines in place. One is at the thermostat, the other is on top of the engine. Remove those, then pop the hard line out of the thermostat. No coolant should come out at this point.
    11. Now you have enough space to get the oil cooler off. There are four 6mm bolts that secure it on. Be prepared for oil and coolant to spill out. There are two bolts on top that secure a bracket in place; make sure that bracket comes out with them. The two bolts on the bottom are easy to get to; use a mirror to find them, or just feel around for them.
    12. Pop the oil cooler off! It might be a bit stuck on there, but that's okay. Nothing will get damaged here.
    13. Remove the hose that connects the oil filter housing to the PCV.
    14. Remove the oil pressure connector. It's towards the back of the oil filter housing.
    15. Now you're ready to pull the oil filter housing! Oil and coolant will come out, so be prepared. It's four 10mm bolts that secure it. Once they're undone, pop it off like you did with the oil cooler.
    From there, you're pretty much done. I want to point out that there's no need to remove any clamps for the coolant hoses; the guy in the video did, but the hoses on my car are welded to the metal pipes, so I didn't want to try pulling them off. Make sure to replace the gaskets, clean the housing and cooler well, and do everything in the reverse order. Make sure to change the filter while you're at it too. Any questions/tips/changes, feel free to let me know!
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Mar 24 2013
    Oakdale, CT
    The only think I would add, is that you don't really need to drain your oil to do this. You can simply drain the filter housing and then add ~½ quart back in when you're done.
    -Adam
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    True. I thought that draining the oil and coolant would drain the fluids from the oil cooler/oil filter housing. I was very, very wrong. But, I did need to change the oil anyway, so it wasn't a big deal.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by kaz02a4 View Post
    That's funny, I thought the same thing about pulling my turbo yesterday. NOPE, huge mess everywhere.
    -Adam
    Veteran Member Four Rings brandonpham's Avatar
    Dec 06 2014
    Great job, I'll use it as a reference to save some time lol. Very simple for anyone with decent knowledge. Surprised no one had done a prior DIY for these.
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Sorry to hear man. How did the rest of the job go at least?
    Quote Originally Posted by brandonpham View Post
    Thanks! I was surprised too, I couldn't find any DIY other than that video. It is pretty straightforward, just as long as you take your time.
    I really hate G12 now though. It gets everywhere, it's slick, and sometimes it's a pain to bleed the coolant system.
    Dec 06 2014
    With you on that bleeding issue. I had to purge the tank several times to get those damn fans to kick on and the thermostat to open. It was just so slow when bleeding. Otherwise coolant system in my car has been clean. I had my local Audi dealer price match online so i matched coolant prices and other things.
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    How did you purge it? Crack the bleeder screw on the top of the hard coolant pipe, run the car with the tank cap off, or pull the heater core hose?
    Mine has purged fine so far (fingers crossed it stays that way).
    Veteran Member Four Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    Can a moderator pin this to the DIY?
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Quote Originally Posted by pat_do View Post
    Hope this gets added to the DIYs, and I hope that it helps people!
    Mar 24 2013
    Oakdale, CT
    Well, I had to remove/reinstall the turbo twice in two days if that tells you anything. I'm getting pretty good at it.
    -Adam
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    That's brutal. Did you finally get it sorted out?
    Feb 19 2012
    Montreal
    Best DIY ever since i asked kristokes to sticky it
    Veteran Member Three Rings ktish's Avatar
    Nov 05 2012
    Would 100% recommend the Airlift II coolant system refiller for anyone who has trouble with bleeding. Easy to use. Bled my father's elise first time no issues. The diesel guys swear by them too as I believe the duramax motors are notorious for holding air bubbles.
    Mar 24 2013
    Oakdale, CT
    Ya, it works fine now.
    -Adam
    Nov 05 2012
    NH
    Just an FYI i know its a Ten MM for the Oil Filter Housing bolt but i found the allen can work better for the top too, especially if the allen you have is a 1/4 drive.
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    This was a to-do this summer before it happens. Now it's official that it has to be done. Wondering if the whole unit should be changed as well.
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Quote Originally Posted by ktish View Post
    No need for a vacuum fill tool. About 99% of the time i just remove the upper coolant bleed port and squeeze the upper radiator hose, plug the bleed port, let go of the rad hose, and unplug the bleed port with your finger. This way you create vacuum without expensive tools and saves time setting up equipment. Do this simultaneously until coolant overflows in the bleed port.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Established Member Two Rings mjfrizz's Avatar
    May 06 2010
    St. Louis, MO
    Is draining all coolant necessary?
    With a hose clamp or two I was thinking I would be able to drain just enough
    I have parts ready for the morning. Already detached/moved most of the crap necessary, annoying
    May 06 2010
    St. Louis, MO
    Seemed like about a quart of coolant drained out from coolant pipe/hoses and oil cooler. So doing this without draining entire system is possible, but I don't think it saved much time. Still have to purge system no matter what.
    Not difficult job, just annoying, particularly for coolant connections. Those rubber hose to pipe joints always suck, especially after 120k miles.
    Many thanks to OP for the help.
    Senior Member Two Rings aviator79's Avatar
    Apr 10 2012
    Suffield, CT
    I sure wish all the pics where still here. About to attempt this.
    edit on reload more pics showed up.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Apr 10 2012
    Suffield, CT
    Im assuming the only way that coolant gets in oil/oil in coolant is if turbo fails, oil cooler fails of HG fails?
    Edit, seems that coolant is not brown, just looks brown in blue bucket. Oil looks OK so think I am fine.
    Have to get 6mm triple square.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    Quote Originally Posted by aviator79 View Post
    I know this was a while ago just wanted to clarify for future peoples that our turbos are NOT coolant cooled, they are oil cooled so no a failing turbo does not get coolant in your oil or vice versa
    Also just wanted to point out coolant and oil mixing is very clear as it looks like yellow milk, you would most certainly see something was up and would not look anything like coolant nor oil, oil and water mixes to a whitish yellowish milky substance
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by pezgoon View Post
    The turbo has coolant and oil lines right?
    My respray thread
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by Okedokey View Post
    I'm about 500% sure that all of my turbo swaps have included removal or replacement of both oil and coolant lines on the turbo.
    If a chra physically cracks internally oil and coolant can mix. In a combustion engine without any oil froth reduction (baffle pan, external oil pump) your engine oil itself can become brownish yellow nasty looking crap. This whitish yellow milky stuff can also happen due to pcv or crankcase pressures not being its best (frozen/full catch can) this creates condensation in the engine and can resemble oil/coolant mixture. anyone one running a catch can will be able to simply test this themselves. Being winter start your car and remove oil fill cap, while the system warms up you likely see yellow/white/milky stuff on the inside of the oil cap. Usually once the system is hot and pcv lines thaw this milky shit goes away.
    Jul 25 2016
    new hampshire
    Quote Originally Posted by canadianA4B7 View Post
    It does?? I thought I'd only seen oil lines going into it, although I have never pulled mine out I will have to take a look this evening ha
    So why didn't they just make it 100% coolant so that it wouldn't cook the oil and put the engine at risk of various issues from it doing so lol
    Eric
    Feb 15 2016
    Cambridge,Ontario
    The only thing I will add is you are 95% of the way there in labor to replace the thermostat and you have the coolant drained so I would definitely do this at the same time given the rate our stats fail. in fact if I had read this when I replaced my stat I would have done these two seals in a heartbeat.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by mjfrizz View Post
    Have the parts, about to do this. Question: when you finally pull the oil cooler off the block, does much oil and coolant mix?
    Meaning, if you are as picky about coolant purity as I am, will I want to flush and change the coolant? Or can I just use a wet dry vac and suck the oil-contaminated coolant out of the opening in the block brefore I put the cooler/gasket back on?
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Feb 24 2004
    Minneapolis
    Finally did this yesterday. Not hard, just time consuming and boring.
    My only tip? When the oil cooler comes off and a bracket drops to the floor in a puddle of coolant - don't say f***k it I'll get it later - then wonder why you can't get it back together until you finally look under the car and say, "f***k it, I remember that dropping an hour ago.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by mtroxel View Post
    I've done this a couple times on various cars now, and I try to time it with an oil change. I only ever just top off the coolant and have never seen any evidence of oil mixing with coolant as a result.
    -Adam
    Mar 24 2013
    Oakdale, CT
    Turbos are water cooled on our cars. The oil is there for lubrication (it provides a little cooling also) and the coolant makes sure it doesn't get hot enough to cook the oil. The coolant can actually circulate by itself after the car is shut off. This makes a turbo timer a useless addition to our cars.
    -Adam
    Feb 24 2004
    Minneapolis
    That was my impression too. When the cooler was hanging by that hose, the coolant dripped out of its hole but it wasn't above an oil passage. I'd be surprised if I lost more than a couple cups of coolant.
    Is that just a percolation action?
    Jul 25 2016
    new hampshire
    Interesting, last turbo I had was only oil cooled and so I didn't realize ours was water cooled.
    How can it circulate by itself? Is there a separate electric water pump?
    Eric
    Apr 10 2012
    Suffield, CT
    Just did seals and still leaking so got a URO after market housing to fix properly. Going to drain oil as needs to be changed but how much coolant will I loose?
    This time I am not draining coolant from bottom by radiator. Will more come out if I dont? Reading posts above seems not need to drain
    Do I need to drain overflow tank? pinch off any lines? I just dont recall where the lines from from so not sure if all the coolant can drain out down to the level of the cooler or what...
    I have 1.5 qt of what I assume is unmixed G13, so 3qt mixed. Hope that will be enough to top back off. Of course if I mixed water in jug and did not label it a 50/50 mix for some stupid reason than I will only have 1.5 qt not 3qt of mix. Assuming I will be able to tell difference by pouring some out as should be darker pink if not mixed.
    Cant see pictures again. Not sure how they showed up when I reloaded as i posted. Maybe a glitch. I should be able to figure it out as I did it before.
    Going to go buy a tray to catch all the fluid as I just cleaned my garage floor.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Apr 10 2012
    Suffield, CT
    Comparing URO housing to old OEM it looks about the same. Noticed inserts for housing bolts were not all flush where meets block like oem so you need to be sure not to over tighten as you wont get a solid stop like oem.
    Main worry is obviously valves but hope they work as no way to test.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Apr 10 2012
    Suffield, CT
    Comes with filter and gaskets. URO on left. MANN on right. Looks ok. More pleats but material thicker and less support attopand bottom. Certainly less surface area and likelymore restrictive. Save for emergency.
    Gaskets are probably fine. Im using them. Pulled them out to oil.
    Note pressure sensor must be transfered. 24mm deep socket. No o-ring even thou looks likethere should be one.
    Filter cartrage housing seems solid. Will save old one just in case.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Apr 10 2012
    Suffield, CT
    Looks already diluted. Dont have neq bottle of concentate to compare to. But think i already mixed water and forgot to lable.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Apr 10 2012
    Suffield, CT
    Pan saved me from a huge mess. Why i never bought one before idk.
    $12 at HD.
    Coolant loss is 6 cups or 1.5qt.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Senior Member Three Rings fallingreason's Avatar
    Jul 07 2011
    Bicycles
    SF Bay Area
    Was dreading this job, but after going through the DIY a few times it doesn't look too bad. Tight engine work jut scares me sometimes.
    2 questions:
    Is this done entirely from the top of the engine bay, with the exception of draining/catching fluids?
    What extra work is needed to change out the thermostat? Just removal of the other lines? I have one on hand and will do a coolant flush as I'm due anyhow.
    TIA
    2013 B8.5 Q5 2.0T
    Apr 01 2018
    Calgary
    Is the URO oil filter housing assembly a sufficient replacement? or should we get OEM part?
