Results 1 to 17 of 17
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Why are my Zimmermann Brake Rotors Not Fully Z-Coated? Received Rotors from FCPEuro
    I was intrigued by the Zinc Coating Feature and ordered the Zimmernann Rotors earlier this week. I ordered from FCP Euro (aka FCP Groton) and was told the rotors were available in Connecticut. I was pleased since I would receive the package within 1-2 business days. When I received the tracking info, I became extremely concerned because the Rotors appeared to be coming all the way from Carson, California.
    I received the Rotors today. First, I was hesitant to open the box since the Box arrived crushed on one of its edges; either could have been handled this way by FedEx Home Delivery or been in this condition from the very start of its journey. As I opened the Zimmernann Box within the Package, areas of the rotors were missing the Z-Coat (as pictured below).
    I'm not sure what to do now. I understand the Z-Coat is suppose to come off the more you drive and apply the brakes; however, I'm not sure how long these rotors will live up to its anti-corrosive properties.
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    pretty sure your fine. thats how some factory rotors come , they grey stuff is there to keep them from rusting and will burn off after a few stops. i believe the coating really only applys to the hub surface and the veins
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks, I should be good to go ahead with the install then. Hopefully, these rotors will last.
    Quote Originally Posted by AudiTechS4 View Post
    Current:
    70,xxx Miles
    182,xxx Miles
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    This^
    The coating on the rotor surface will be scrubbed off immediately. Unfortunately, the contact surface will rust.
    Senior Member Four Rings
    Jan 12 2015
    Aurora IL
    Because the coating would wear off the first time you hit the brakes.
    2004 A6 S-Line
    Dec 27 2014
    2013 Audi Q5 3.0T
    That should be fun to watch.
    Quote Originally Posted by Brandon002 View Post
    Current:
    70,xxx Miles
    182,xxx Miles
    Jan 12 2015
    Aurora IL
    Unfortunately you won't be watching unless you can somehow drive with your head next to the wheel.
    2004 A6 S-Line
    Dec 27 2014
    2013 Audi Q5 3.0T
    Haha, I should have chosen my words more appropriately.
    FCP did a daring job coordinating logistics for this order.
    Current:
    70,xxx Miles
    182,xxx Miles
    Established Member Two Rings jsmorris's Avatar
    Aug 17 2012
    2003 RS6 Sedan, 2021 Jeep Gladiator Rubicon Diesel, a few Ducatis
    Houston, TX
    Quote Originally Posted by arjun90 View Post
    ... First, I was hesitant to open the box since the Box arrived crushed on one of its edges; either could have been handled this way by FedEx Home Delivery or been in this condition from the very start of its journey.
    Packaging grade is about a D-. Lots of care with those instructions.
    Jan 12 2015
    Aurora IL
    Thankfully brake rotors are steel and a dented box doesn't mean a damaged rotor. Imagine the type of force it would take to damage a boxed rotor? They'd have to drop that sucker from about 15 stories up.
    2004 A6 S-Line
    Mar 05 2013
    CA
    No. It will likely take over 200 miles. As instructed per Zimmerman themselves, who say to wait to do anything like pad bedding procedures, until the coating is fully scrubbed off by the pads. I had these in the past, and it took a while to scrub off. There is no use in bedding, the point of which is to even out rotor and pad surface (and cook out pad resin), if you're depositing pad material onto a sacrificial zinc coating that will scrub right off.
    The coating is a sacrificial layer of zinc on top. It is not meant to protect the rotor face contact surfaces, nor does it. Pads scrub it off. It's meant to protect things like the cooling vanes and hats from rust. If it's scratched off in other areas, you can always spray it with something like Wurth SBS-II.
    Clicky
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    To save the next post after you install these, they probably will rust a little inside the viens and on the hub over time but they won't rot or fully rust over which is the whole benefit. They are only brake rotors not a fancy paint job
    I have a set that are over 3 years old on my TT which sits a lot, they have some surface rust but they don't rot away like a generic parts store rotor from china
    IG: d3bel1o
    Dec 27 2014
    2013 Audi Q5 3.0T
    The stock rotors on my Audi occasionally developed rust, typically during Winter; also when the car would be sitting for extended times. Fortunately, the rust would come off after driving.
    Current:
    70,xxx Miles
    182,xxx Miles
    Jan 12 2015
    Aurora IL
    Your Zimmerman rotors will develop rust as well. Please don't panic.
    2004 A6 S-Line
    Registered User Four Rings FCPEuro's Avatar
    Jul 30 2009
    Milford, CT
    Hello,
    I remember talking with you about the Zimmermann brake rotors for your Audi. I'm sorry about the box being shipped to you in that condition, this most likely happened during transit.
    The Z-Coat is designed to protect the rotor hats along with the outside edges.
    Best Regards
    Dave
    Sep 11 2009
    NE
    Quote Originally Posted by Dave@FCP_Euro View Post
    Hello,
    Best Regards
    Dave
    ^ this.
    The only part where the coating really matters are hub sides and outer edge, these are the only visible parts once you install the rotors and having these rust is what the coating is there to prevent.
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thank you
    I'm glad I went with the Akebono pads and not the Textar ePads. The Zinc coat on the Zimmermanns is useful but for appearance reasons only. I could have resurfaced my old rotors but didn't find it feasible because they would have had to be replaced eventually anyway.
    Old pads weren't that bad.
    I still sense the previous rotors were a tad bit warped and the pad surfaces were not uniform, thus explaining the growling when decelerating.
    Now I can brake with confidence, haha
    Current:
    70,xxx Miles
    182,xxx Miles
