Results 1 to 15 of 15
    Jan 25 2013
    United States
    Bluetooth in your Audi B6
    Hey guys,
    I recently had a 6-speed swap done, and now i'm interested in a bluetooth receiver in my audi and the standard head unit. I"m curious if any of you have added a bluetooth unit to your standard system, bluetooth that uses an aux port, or a different head unit. Can you hear well when someone calls you, and do they hear you well on the other side? Cheap addon or not worth it? Any opinion welcome.
    Thanks.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    i'm currently using this with my Symphony II+ radio.
    http://www.amazon.com/TaoTronics-Blu.../dp/B00RSZWK1W plugs into aux input, works wonderful as a bluetooth mic for voice calls also.
    Jan 25 2013
    United States
    Quote Originally Posted by BARRY View Post
    Did you have to purchase the Symphony II+ unit or did it come with your car?
    Nov 02 2007
    SF Bay Area, CA
    came with the car. previous owner installed it. they come on B7 A4/S4's. sell for about 120 on the audizine market place.
    Jan 10 2013
    03 A4 Avant 1.8TQ
    South San Francisco, CA
    http://www.dension.com/products/bluetooth
    Or go the better route and get an aftermarket double din with USB for music and add the bluetooth mic
    Veteran Member Three Rings USAF Long's Avatar
    Nov 05 2010
    Salt Lake City, UT
    Yep... got a kenwood dvd deck w/ aux input, usb, bluetooth. It rocks and you can watch movies on long drives.
    - Scott Long -
    2002 Audi A4 1.8t Quattro - 5-sp | 3M Wrapped | Test pipe | Custom Exhaust | Tint | 19" Staggered Wheels |
    Veteran Member Three Rings evolution2147's Avatar
    Mar 25 2012
    AZ
    Quote Originally Posted by Zdrajca View Post
    Hey guys,
    Thanks.
    I am pretty sure the only way you can use the stock Bluetooth is with the RNSE. I know you can use it with the symphony 2+ But you will need a multi function steering wheel to make and answer calls. I am uncertain if the symphony 2 is even compatible with the Bluetooth module. (It may be but will still require a MFSW for functionality.)
    Also the factory Bluetooth isn't that amazing compared to most newer cars. I would only consider if it you definitely want to keep a factory look
    Jan 25 2013
    United States
    Quote Originally Posted by USAF Long View Post
    So you just replaced your head unit with an aftermarket double din with all the bells and whistles there already?
    Active Member Two Rings BigJME's Avatar
    Mar 28 2007
    '05 A4Q 3.0
    Austin,TX
    I'm using a GROM unit with my factory head-unit
    J. T.
    Jan 25 2013
    United States
    Quote Originally Posted by BigJME View Post
    J. T.
    Which factory Symphony head unit do you have?
    Nov 05 2010
    Salt Lake City, UT
    Yep. Kenwood DDX371.
    - Scott Long -
    Nov 05 2010
    Salt Lake City, UT
    - Scott Long -
    Jan 25 2013
    United States
    How is the reception on the other side of the line. As in people you call. Do they hear you well?
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    I'm using (and have been using) an OEM setup with my RNS-E for five or six years. It works well enough - I can make/receive calls easily and clearly (although the BT in my BMW is much better, but the car is also nine years newer). I went with an OEM setup because there weren't many aftermarket options at the time - nowadays, the choice is a bit tougher.
    Nov 05 2010
    Salt Lake City, UT
    They can hear me pretty well. There is a microphone level adjustment that shows on the screen when you are on a call with a + and - button so you can increase or decrease the mic sensitivity. Mine is set to +7 I believe. The mic is mounted above the steering column at the bottom of the gauge cluster trim. So I just speak and its in the direction of my voice while driving. I only take a couple calls per week while commuting but it's much easier than holding a phone to your head or trying to hear on a speaker phone while holding a phone and trying to deal with traffic.
    - Scott Long -
