Results 1 to 8 of 8
    Established Member Two Rings kamdyka's Avatar
    Oct 04 2013
    Surrey BC Canada
    Humming noise from front of the car
    hi there,
    my b7 s4 is having some noise related issues. It is most prevalent on the highway when i'm doing around 45+. Slight humming noise almost as if theres some sort of rubbing. Isolated the problem to the front. Could this be my wheel bearings? It doesn't occur when I turn just mostly at high speeds. Any suggestions would be great.
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    The wheel bearing is the first part I would suspect. Pretty easy to replace, just make sure they're torqued to spec.
    Also, check the condition of your tires (including pressure) and rims (make sure there are no bends).
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Mar 06 2013
    My guess would be wheel bearings. So when you're going straight you hear the humming, and then when you turn slightly you don't hear it?
    Black B7 S4 6MT
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    If the hum increases in noise with an increase in speed, it's a very good chance it's the wheel bearings. It could be the axles/cv. How many miles are on them/car? If it's a manual, when was the fluid changed last? If it's a tip, has the front diff ever been serviced? Are the belly pans secured? What brand tires are you running-how much tread is left?
    Active Member Two Rings Smokn337's Avatar
    Aug 26 2014
    '05 S4 Avant, '09 VW Routan (aka Dodge Caravan)
    British Columbia/ Kanada
    I have a hum from the front end of my B6. It's the control arms on my car.
    '05 S4 Avant: brilliant black with blue Alcantara interior. Bi-Xenon E-codes, tint, smoked markers, Ultrasport 18's so far...
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Could be a gnome in your engine bay. I've heard they like to hum when they get bored
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Could be a cupped tire.
    Old Geezer, formerly known as Stud Muffin
    Oct 04 2013
    Surrey BC Canada
    car has 36,000 miles and its running michelin A/S super sports on OEM wheels for winter setup
    its 6 mt & Fluid was done before I bought in November of last year I believe.
    Humming noise is present at speeds starting from 30 mph onwards and its most occurant on windy roads
    Its not that loud, had to listen pretty carefully to even recognize it
