I have a 2000 Audi S4 with GIAC chip, new 710N diverter valves and have been performing a boost leak test on my car thanks to all the great information I found on this forum the past year. I have fixed all the boost leaks that I can find. I am using an air compressor and a boost leak tester with the gauge that I purchased from turboboostleaktesters.com
So the issue I am having is that when I do a boost leak check it is maxing out at about 13-14psi. I can't find any other boost leaks. The strange thing is when it hits about this range I can hear (and feel) the N80 purge valve turn on and it sounds like it is bypassing air thru it. I tried it with the electrical connection to it plugged in and unplugged. Is this normal? Could the N80 purge valve be going bad or is this a symptom of another problem? Any help would be very appreciated. Thank you!
