I am putting some new life into this thread...
I am not happy with the stock S3 brakes. But I have been warned...
Yesterday I went to my 5th track event this year in Calabogie and finally I was able to use my Pagid RS29 pads I waited so long for. In the other 4 events I went through 2 sets of OEM pads. And after the second day they started to glaze over despite a cool down lap…
Now I know why…
I was finishing a 25 min run of fast laps. The pedal started to show fading, it went all the way down to the floor in the last couple of turns, still good braking action but you had to push all the way down. And then the course got black flagged due to a car with a blown head gasket just when I wanted to go on a cool down lap, I had to come in right away so no chance for a cool down lap. But now I was able to measure rotor temperatures using my IR temp gun.
I started with the front left. 495Deg… CELSIUS!!!! That is 923F….
Front right, 460Deg and both rears were at 195Deg.. all Celsius. My buddy behind me in his M3 had the front left at 300Deg C.
That is WAY too much heat in the rotors. Now I know why I had brake fading despite brand new RBF 600 fluid…
The Pagid pads are great, good initial bite and much better control of modulation compared to the OEMs, and not glazed at all, no noticeable wear but the yellow color started to flake off (!!). However today the pedal has still a lot more travel than before the track event. I will have bleed brakes tomorrow. I hope that will help.
So lesson learned: Either I install some sort of DIY cooling ducts for the front rotors or I have to get a BBK. Not sure if slotted rotors would make a big difference.
But I don’t want to shell out 4k CAD BBK (that is what you pay in CAD and with taxes..) because I want to keep my 17inch winter set up (plenty of winter up here) and I planned to go with a dedicated wheel and tire set for the track days in 17x9 with 245-45/17 tires, they are significantly cheaper in this size.
Nice first world problem.. But I have still at least 3 more track events this year…
Anyone with an idea (other than BBK…)?
