Results 1 to 12 of 12
    Dec 17 2014
    Chicago
    Milltek exhaust clamp alternatives
    Hello,
    My car has had it's Milltek cat back exhaust system on it for over 10 years. The exhaust clamps are rusted out and I had my first one fall off. What do you guys recommend for replacements?
    All the local parts stores have cheaper looking ones, compared to the clamps that come with the Milltek system. I want to say my exhaust is 3 inch. Here's a stock image of the Milltek clamps:
    This is more along the lines of what the local parts stores have in stock. Without wasting money on doing my own test.....are these sufficient, or a waste of money?
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    Quote Originally Posted by SnyperBob View Post
    Hello,
    I highly suggest not using the u bolt style clamps. They will deform the pipe, Napa/O'Reily or any other parts stores should have the t-bolt style exhaust clamps or even band clamps.
    Dec 05 2007
    If it's a slip fit connection, use one of these type...
    ...http://www.ebay.com/itm/3-00-3-Torca...71b0cf&vxp=mtr
    Torca is cool because you thread into the clamping peice, and not a bolt with nut type deal.
    Jun 10 2010
    Autozone sells clamps similar to these.
    Dec 05 2007
    There will be differences. Mainly quality. Actually...only quality. But you get what you pay for.
    Dec 17 2014
    Chicago
    Thank you, I would like to stick with the T style, over the U clamps. I'll check Napa and O Reilly, I didn't see anything big enough on Autozone's site.
    Established Member Two Rings mrbillydee's Avatar
    Jun 01 2014
    NC
    Maybe check into a muffler shop and see if they can do a v band setup?
    Apr 10 2010
    I used Acuseal style exhaust clamps (or similar) for slip fit connections when I had a miltek system.
    Here's the Vibrant variety
    http://www.summitracing.com/parts/vpe-1167/overview/
    Hello,
    Veteran Member Three Rings goalieman24's Avatar
    Mar 29 2011
    Those actual Milltek clamps can be ordered.
    I went through the same thing less than a year ago, and was told by Milltek that any of their dealers can get them for you. I just quickly checked my e-mails but couldn't find exactly where I got them. Will try and look for an invoice at home later and let you know.
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Mine are all leaking. im guna weld all the connections together evrywhere but one set of the clamps on the downpipes. Then cut that out and put in a nice v band clamp setup so it wont leak again and still be able to pull it aparrlt and off vehicle when doing work.
    Mar 29 2011
    Griffin Motorwerke is where I got them. I think they have individual clamps listed on their website (www.g-werke.com), but I got the entire "kit" for much cheaper than buying separately. I'd give them a call.
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    I can get you the clamps Milltek sends with their kits if you want to put on what came off. Just shoot me a PM
