Originally Posted by
will13k7
nice! thanks for sharing! got me considering changing my own oil too. haven't done that for ages.
hey no problem.
i do recommend doing it even before the 1k miles if the car is brand new. i seems the oil either broke down faster or it was just not meant to stay in there that long.
nefkntym
949, what extractor is that?
Draper 77057
Expert manual or pneumatic oil extractor.
after researching for the best one i can find i found this model. it isn't sold locally but overseas. im not sure why. the most popular ones in America is the mityvac.
i have never used the mityvac so i don't have any opinion on that brand. this model was considered a professional model.
while i was researching i came up with some criteria's that i needed and some i wanted to avoid.
-it had to be big enough to hold 6qts. obviously the car holds or supposed to hold 6qts and so this is a minimum.
this one holds 10.5qts.
-the hose needed to be strong, clear, and wide. what i mean is that the walls of the hose needs to be thick enough for the suctioning and be clear so i can see if oil is siphoning through. plus the diameter needs to be wide enough so that thicker oil can flow through easier. which makes it evacuate faster. you will notice in video reviews of other models they take a long time to evacuate oil.
this one has a clear tube. the diameter is wide. to support and wider diameter, there is flexible metal coil inside the tube from beginning to the end of the large tube. in other youtube videos they mention that a weak tube will collapse while being used. other makers are using cheap tubing and can cause this issue. i didn't think saving a few bucks here and there to be helpful because you will need to replace those cheaper items and therefore spending the same amount on a better unit. so this unit is a very good quality as i can tell.
- the main unit needs to be clear. the idea is simple. to be able to see how much oil is in the container.
this one is clear as you can see in the picture. plus it has the measurements on the side so you can see how many quarts came out.
-manual and pneumatic. it needed to be at least a manual version. most of the time ill just need to work on one car and if i need to take it to another location then i can just pump it. on some days im super lazy or need to work on multiple cars or even need something to work faster than me just pumping, this unit can do both. it will work with any size compressor to make the job fast and easy.
this unit will work with me pumping the unit or hooking it up to a compressor even if its a small bike compressor as well as a larger compressor.
-quality is one of the most important factors for me. if the unit breaks down after a few uses then it is useless. so far most of the reviews says its a robust unit. only time can tell for me as its an occasional used unit in my house. it does feel like a quality unit and is heavy with metal parts for the attachment on the compressor side. the plastic attachment seems like its in good quality and the O-rings are items i know i can replace myself from the hardware store down the line when they become old.
this unit seems to me like a solid unit so far.
-attachments needs to be all there for many cars. there are three attachments that come along with the unit. they all are push in attachments. no lock down. at first i thought that it would be an issue but after i used it once, i noticed that there is no need to have a locking mechanism for that. plus it makes it really easy and fast to switch attachments to the hose. the one i used for the audi s3 is the small blue metal attachment. its got a metal inner and is covered with a rubber outside. very good quality there. it wont collapse nor will it break in the dipstick tube on the car. it is also perfectly long enough with a few inches to spare to reach all the way down the dipstick tube to the oil pan down below.
this unit have three attachments. one will fit perfectly for the audi s3 2015
this item costed 189.00 shipped. its not a bad price being its a shipped price.
since it was coming from out of the county they estimated about 6 week for delivery.
in my case, it was to my surprise it only took about 2 weeks and was at my door step. when it came i had no clue what it was because i was waiting for a month out not 2 weeks.
