I think this is what you want:
You won't find any power at the clutch switch, because it's actually delivering a *ground* signal to the relay, and there are no fuses involved with that aspect.
This is for a 97-99.5, but the wiring is pretty much identical for the later years too. The circuit is quite simple. If there is an immediate need to get the car going, I'd bypass the starter relay with a jumper wire across the load contacts. Note that this will disable all starter safety features. The car will start in gear, and immediately run over people. It will
kill them dead. This is serious, so be careful.
Since you have the knee bolster removed, I would suggest you begin testing of the circuit at the starter relay location. You can test almost everything from that spot. There are 4 pins on the relay. 2 should be hot (12v+) with the key held in the START position. 1 should be ground with the clutch pushed down, and 1 should be a low resistance to ground through the starter solenoid. On that last pin, if you momentarily tap 12v+ to it, the starter should engage, like...right meow. So make sure it's not in gear if you decide to do that test. Actually for any dealings with this circuit. Neutral selected with e-brake pulled is a good idea.
