Results 1 to 8 of 8
    Veteran Member Four Rings ArcticBoost's Avatar
    Jun 19 2005
    2005 Arctic A4
    L.I, New York/CT
    Is it ok to drive on 3 18's and 1 17's, just as a spare in case a tire blows out?
    Im hopefully buying new 18's and i wanted to know if i could keep one of my 17" sports as a spare. Thanks
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    it would as long as you realise/understand that you shouldn't be driving for miles and miles and that combo and that it's only a temporary measure... also make sure that your tires on both the 18s and the 17 are of the correct size... i.e. say your 18s are 235/40R18 and your 17 is 235/45R17...
    MY2024 B9 Q5 55 TFSIe: GlacierWhite||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Active Member Four Rings Ptwiggens's Avatar
    Jul 19 2005
    APR Stage 3+ '02 1.8TQM A4
    Colorado/Manhattan
    Wouldn't that seriously screw something up if you have quattro?
    Bam!
    Sep 21 2005
    2010 B8 A4 Qt
    In my opinion, it should be ok.. because;
    1. some cars have like 13 or 14 inch spare wheel and tire for emergency use.
    2. i believe that the tire on 17inch wheel has bigger/thicker tire compare to the tire on 18inch wheel., which would be similar size with tires on them.
    Correct me if I'm wrong.
    current: 2010 Audi A4 2.0T - Blesk 5000K D3S bulbs, LED interiors, Blesk 3000K HID fogs, Blesk LED festoon on license plates, carbon fiber wrapped roof, + more upgrades may be on the way upon approval from the boss (wify)
    past: 99' Audi A4 2.8, 03' B6 A4, 2009 IS250, ACURA TL-S, 240SX, + 13 more...
    Veteran Member Four Rings xonetruthcrewx's Avatar
    Apr 30 2005
    Tehachapi, CA
    As long as the rolling diameter is the same you will be fine.
    Registered Member Two Rings
    May 21 2005
    atlanta
    bad idea for any period of time. The resistance of the two wheels prob not the same. Same reason you dont drive around with unequal tyre pressures. May not be healthy for the fluid at the minimum.
    Registered Member Four Rings Vortec4800's Avatar
    Oct 10 2004
    2005 A4 1.8T
    Phoenix, Arizona
    Like truth said, as long as the rolling diameters are the same you should be fine. Don't drive with it on there all the time, but even if you got all 17's it would be the same. The weight of the stock spare is going to be different than the other wheels, even if they're all the same size.
    Moral of the story is don't worry about it, but if it happens get it taken care of.
    Veteran Member Four Rings teutonic_blur's Avatar
    Puerto Rico
    What truth and vortec said.
    If A is a success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut.
    Albert Einstein
    It's not that I'm afraid to die, I just don't want to be there when it happens.
    Woody Allen
    2003 A4 1.8T FWD 5M
    Revo SPS1, K&N drop-in, NGK Coppers
