I have not been able to have time to take off a wheel and measure properly but I did take a quick measurement because when I looked at the current tires that are on them and it does look like the 235/35r19 tires are kinda stretched. with my past experience with tires, if there is a stretch to the side walls then it is closer to the lower rim measurements of the tire specs. each tires have a max and min width a tire should be installed on properly by the manufacturer.
almost all of the tires on the current market that have tires with 235/35r19 have rim width specs of 8.0-9.5 inches. I then took a quick measurement with a ruler and noticed its beyond 8 inches from side to side of the outer beads of the rim (not tire). so its either 9.0inches or more wide. I hope its like 9.5 or even 10.0 inches.
wheels from factory, when up sizing, I have been able to always increase it about 1.5 inches without major fender surgery. this is why I hope its 9.5-10.0 as a lot of nice wheels are up there with a lot of concavity structure to them.
is there anywhere online that can confirm the actual specs? I cant find any.
