Originally Posted by
02s4audi
How long will the iridiums last? Are they better than the platinum plugs the car comes with?
No, basically the same thing, run what Audi recommends.
02s4audi
Then what are the benefits of each because everyone I've heard from says run copper. Which should I realisticly run?
The difference between copper and iridium/platinum is minimal if you are putting around on stock boost levels, once you start upping your boost you will need to begin to think about the other variables (gap, spark strength, ignition components, etc..). As has been said, if you don't mind wrenching on your car, replacing plugs every 10k, imo, is well worth the savings that is foregone by not using the longer lasting iridium/platinum plug (on stock or modified boost levels). I run copper additionally because there is a better chance that I will burn my plug down first instead of the motor where the same cannot be said about i/p.
