Results 1 to 8 of 8
    Senior Member Two Rings Frag's Avatar
    Mar 25 2014
    Montreal, Qc
    KW V2 Coilovers question for you guys
    Can you adjust the dampering without raising the car?
    Its a dumb question guys, but I was not able to figure it out looking on googles.
    Briefly, if I go on a road trip with the familly, can I go outside few minutes and change the damper setting easily? Or I will need to jack the car up at every corner to make the adjustments?
    Veteran Member Three Rings Maitre Absolut's Avatar
    Aug 06 2009
    RS6, X3 30e
    Montreal/Toronto
    FYI instead of starting new threads you can just follow up in the ones you have already started....
    KW DDC might be what you are looking for
    2023 RS6 | GW / ER | CTS res delete | Ghost links | H&R 10/12
    2023 X3 30e
    2019 SQ5
    2018 M3 CS
    2017 Macan GTS
    2014 S4
    2009 A3 3.2q
    Mar 25 2014
    Montreal, Qc
    No one has the V2!?
    Mar 25 2014
    Montreal, Qc
    I know that some of you have the KW V2 ... still want to know if the dampering can be adjusted when they are installed.
    Feb 02 2014
    Focus RS, Audi S4 & S5
    Knoxville, TN
    When I went searched this is what I found:
    Product Description: KW V2 Coilover Kit 15210097, 2010-2012 Audi S4 / 08-2012 S5 / 09-12 A4
    KW Variant 2 Coilovers: The KW Variant 2 Coilover System is intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences.
    *Features* * Damping technology with individually adjustable rebound * Inox-line stainless steel technology at no additional charge * Individually height adjustable * German TUEV-tested adjustment parameters * High-quality components for long life * Comprehensive documentation for ease of use * Infinitely adjustable rebound damping
    Part Number: 15210097 Notes: Variant 2 Coilovers; Front/Rear Height Adjustable; Front, Threaded Strut Housings; Rear, Axle Adjustable Springs & Dampers; Front Dampening Adjustment Reqr's Shock Removal; Must Disable Electronic Dampening (if equipped) Manufacturer: KW Suspension Rear Lowering: 0.9-2.1in (25-55mm) Spring Rate (F/R): Progressive Front Lowering: 0.9-2.1in (25-55mm)
    Mar 25 2014
    Montreal, Qc
    Quote Originally Posted by whts4 View Post
    Yes I read that already, but no one seems to know if the damper can be adjusted after the coilovers are installed. Can I spend few minutes before going to the track to adjust the damper? Or it only can be adjusted BEFORE installing those.
    Registered Member One Ring anthonybernal22's Avatar
    Apr 30 2020
    Los Angeles, California
    Quote Originally Posted by Frag View Post
    Did you ever get an answer to this question? I just had a set of KW V2 coilovers installed and am looking to adjust a dampening afterward.
    Jun 14 2019
    QC, Canada
    The adjustment is on the top of the shock. In front you would need to cut a hole in the tower shock to access it while mounted. Idk if you can reach it in the back still installed, I think yes you could. Check yourself if you can see the shock top from the trunk by removing the liners.
    AFAIK, the only coilovers system with 100% adjustability once installed is the bilstein pss10.
    Sent from my HTC U11 using Audizine mobile app
