Results 1 to 35 of 35
    Jan 15 2015
    Recommendation on fuel system cleaners
    Curious to know if anyone has tried or can recommend a fuel system/ injector clear?
    Aug 06 2012
    Parker, CO
    The ONLY two I use and would ever use are (in order)
    1: BG44K
    2: Techron Fuel System Cleaner
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Bg44k. /thread.
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    My dad has used BG 44K on several of his cars and trucks in the past. He felt the product worked well and would highly recommend it.
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Fuel system cleaners have no benefit in a direct injection engine : waste of money.
    Aug 06 2012
    Parker, CO
    Quote Originally Posted by S4'ed View Post
    Why would you say this? Is your comment based on "carbon build up" issues? Okay, fine. But you are aware there is the inside of a fuel tank, fuel filter(s), fuel injectors..... all of which see benefit of occasional fuel system cleaning.
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    +4 for BG 44k
    2010 A4 Quartz Grey (click) | APR | Eurocode | GFB | 034 Motorsports | Eibach | H&R | VMR | P3Cars | aFe
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    Yes, it doesn't get sprayed on the intake valves, but my understanding is that it's still able to help with build up due to valve overlap and unburnt product.
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Established Member Two Rings uberwgn's Avatar
    Mar 29 2011
    '06 A6 Avant, 2015 Q5
    Boston suburbs
    Direct injection or not, there would be some value in "cleaning" the rest of the fuel system including injectors. VAG has their own product:
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by b6Hate4 View Post
    Bg44k. /thread.
    Have you ever noticed a difference after running BG44K? I have never used it, and the only effect I have ever noticed after using any fuel treatment is a CEL with Lucas Fuel System Cleaner until I had ran it out of the system and another 1/2 tank. That was on a 2006 TL though.
    I run techron every few months, and perhaps the value is in keeping things clean vs. feeling a drop off if I don't use it.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Jan 06 2013
    MidWest
    If you use tier-1 (Shell, Mobil, etc.) high octane gas you do not need fuel injector cleaner, as gas has plenty of additives.
    Aug 06 2012
    Parker, CO
    Quote Originally Posted by avant-grd View Post
    FYI- octane has NO impact/effect on fuel system cleaning.
    Yes, top tier fuels have the added detergents and cleaning agents so they are really good for your engines.
    I use top tier fuel, but still drop in a bottle of fuel system cleaner every 10k miles.
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    From what I've read, the best cleaner is PEA (polyether-amine), which is the primary cleaning component of top cleaners, like Techron. There are threads at places like Bob is the Oil Guy where people try to figure out exactly how much PEA each additive has, then break it down to which ones give you the most PEA/$, like here. Redline S1-1 and some of the Gumouts often come out on top in some of the threads I've read. I just buy Gumout, because I can get it delivered every couple months for about $5 with my subscribe-n-save discount.
    Here's an entertaining video from one of the BitOG threads:
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Aug 06 2012
    Parker, CO
    Quote Originally Posted by dscline View Post
    Good stuff!!! Thank you
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    +1^
    Stage 1 more than you RS3
    Jan 06 2013
    MidWest
    Quote Originally Posted by treginginco View Post
    Correct. Octane has no impact on cleaning. However, higher octane gas more detergent, according to the spec. Consequently, better cleaning.
    Aug 06 2012
    Parker, CO
    From US DOT:
    High octane gasoline doesn’t outperform regular octane in preventing engine deposits from forming, in removing them, or in cleaning your car's engine. In fact, the U.S. Environmental Protection Agency requires that all octane grades of all brands of gasoline contain engine cleaning detergent additives to protect against the build-up of harmful levels of engine deposits during the expected life of your car.
    EXCEPTION: Top Tier fuels generally use higher quality fuel cleaning detergents i.e. PEA (polyether-amine) --- hence part of the price difference between Bobby's Gas Barn and your local Chevron fuel stop.
    Jan 06 2013
    MidWest
    From US DOT:
    You could be correct and I will not spend time on researching to prove who is “more right” in amount/quality detergent and all.
    The bottom line is that I was accurate in my initial statement that if you use high quality gas, you do not need to use fuel injector cleaner. The prove is in the pudding, as they say: I have done it for many years (not using additives, just quality gasoline) and none of my cars ever had problem with fuel system, and so with many other people that I know.
    The industry that makes additives is pushing these on us and many cave to that pressure.
    Jan 12 2012
    I think it really depends on factors such as the engine, mileage, climate and type of driving (i.e. short trips vs. long trips). The amount of additives in top tier fuel may be insufficient for some combination of factors.
    Peter
    Senior Member Two Rings LmG7119's Avatar
    Jun 03 2014
    MNN
    Sorry to bring this tread out of dead. What do you guys think about Liqui Moly 2007 Jectron and their CERATEC for 2013 allroad?
    Want to use it as preventive measures.
    2013 Allroad Premium Plus UM stage 1
    2003 Allroad EPL Stage1+ straight downpipes catless(sold at 187K miles)
    Senior Member Three Rings Rollin Thunder's Avatar
    Aug 14 2012
    2008 F150 FX4
    Central New Jersey
    Quote Originally Posted by lepa71 View Post
    I currently use both with zero issues. Interested in the Blackstone report soon after using the Ceratec.
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Saw someone posted in the "what did you do to your B8 today" thread that they used all three of these recently so was thinking of doing the same (65,000 miles). Any updated thoughts on this? What do you guys use? How often?
    BG 109 EPR Enging Performance Restoration
    BG 110 MOA Engine Oil Supplement
    BG 44K Fuel System Cleaner
    I'm as cool as a cucumber in a bowl of hot sauce.
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Quote Originally Posted by BeerBrent View Post
    I've never used any, but BG 44K seems like it has great reviews across the board. I am gonna run that and eventually do a deep physical clean of the intake ports like the DIY thread.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Jun 03 2014
    MNN
    Quote Originally Posted by choppstixxx View Post
    Can you post link to DIY thread? Thanks
    Veteran Member Four Rings Marko S's Avatar
    Mar 03 2015
    Probably a waste of money
    Sent from my SM-G925W8 using Tapatalk
    Current: 2019 Audi A4 Allroad Technik
    Past: 2011 Audi A4 Prem+ Stage 2+
    Aug 06 2012
    Parker, CO
    102k miles later ----- BG44K every 10k miles ---- still purring like a kitten.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Thanks for everyone's input.
    Feb 28 2022
    Bayonne NJ
    So I bought a pretty sweet 2010 Q5 Premium Plus 3.2 and to try and combat the known carbon issue with this engine I used redline fuel cleaner it has almost 50% PEA which is proven to clean carbon however alot of poeple say that GDI engines wont benefit I gotta say I saw a slight improvement always 93+ gas best oil early change and some redline every 5 to 10 k
    Feb 15 2016
    Cambridge,Ontario
    there is no tangable evidence any of it works. its all observer bias and " it feels better"
    fact if modern oils and gasses are full of detergents which work very well, the reason you get carbon buildup on DFI engines as pointed out as because back of valves dont get sprayed.. so actually tells you where gas DOES get sprayed the detergents and cleaners are doing their job. But no one want to give up a Billion dollar business do they ? so they will keep pushing these products.
    Put in good quality gas and oil and you will be fine,
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Aug 30 2016
    Los Angeles, CA, USA
    Carbon buildup is definitely a problem with DI engines. Changing the oil frequently prevents/delays all sorts of problems related to combustion residue such as carbon. A little cleaner here and there also keep the injectors and combustion chambers clean and thus less hot spots and less pre-ignition.
    There are intake valve sprays like CRC Intake Valve Cleaner that'll clean the back of the valves. It's a little harder than just pouring something into the gas tank, but I believe it works. My car's idle smoothed out noticeably after one treatment. I also use Gumout Regane (with PEA aka Techron) and that also improves idle smoothness. With 115K miles, the car still idles like new.
    I just learned recently that timing chain stretch is due to the soot wearing away at the timing chain pins (youtube engineering explained). I believe my timing chain is still within spec after 115K miles/10 years because I change my oil more frequently than Audi specifies.
    Oct 24 2018
    Germany
    hahahah
    Aug 30 2018
    anecdotal evidence is anecdotal.
    2019 Audi Q5 - 28k; Arctic White; Black Optic
    2003 Mercedes ML350 - 166k; Gray
    Oct 24 2018
    Germany
    Quote Originally Posted by ps2cho View Post
    I have to agree. Though I do believe that direct injectors are more sensitive and can use a cleaning, I also do these drives from south Germany to the northern end of Norway in one shot. None of those cleaners can come close to what those drives do. The engine runs so much better I would say beginning after passing Stockholm on the way up. Even the Italian tune up doesn't do this much.
    The thing is I also believe that it's not like the old days and in this specific case, additives are needed due to how sensitive the injectors are. My go-to was/is Redline, but I haven't used it in a couple years with no issues.
    Nov 01 2021
    I’ve used LiquiMoly injection cleaner. Just pour into the gas tank with the appropriate fuel amount. After running through the tank my idle revs increase and had better throttle response.
    One or more must of been pretty crusty, or something along the fuel path. Either way 10/10 for me
    Oct 24 2018
    Germany
    Quote Originally Posted by A4_Fire View Post
    Sure you don't have actual engine problems?
