The archives talk about the range control module (that controls the headlight self-leveling continuous adjustment for elevation angle and heavy loads) being located on the "side of the headlamp housing" but I only see 2 ballast modules. When I try and search for the part by name on some parts websites, the diagrams show a single headlight range control module located up by the cowl/firewall area (nowhere near the actual lamps).
So how many modules are there (one for left and right, or just one for both sides)? And where are they located?
If the auto-leveling works on the passenger side, but the driver side is stuck (doesn't move up or down to compensate for hills and doesn't do the usual self-test movement when starting the car), does that mean the headlight itself is bad, or the range control module is faulty?
